performance for a 1984 question
It has been done B4 dual quad. See Simpson36 for his creation here or thirdgen.org. He had custom linkage done by him. I dont think CF linkage will work. so custom needed. Tranny cable is critical to get right.
Here's a pic of his work on a dual quad intake fwiw...
So I guess that means it's been done and don't know how well it works.. The BBC throttle body on a single intake looks a LOT easier to do and setup!
Go with an AED preped Holley 4150 750CFM doublepumper (flows 820cfm after mods), performance distributors with vacuum advance, Edelbrock RPM Airgap intake, COMP Cams 270 5444/5444 106 +4
This is a nice idling motor. 10:1 CR...can take 89 octane if you detune slightly, and not bad gas mileage if you keep your foot out of it.
I used Patriot freedom series aluminum heads CNC gasket matched to a FELPRO 1206 intake gasket that made the runners 190 cc (64cc combustion chambers). They flow about 235 int at .5 and 195 ex at .6 and just cost $895 a pair from Summit.
KB Claimer flat top pistons, scat 9000 stroker crank, scat I Beam rods that clear the block and cam without machining....makes for a nice ride.
BTW....I used an Aeromotive fuel regulator designed for conversion from FI to carb....just added a larger return line and still use the bone stock electric fuel pump and gas gauge sending unit.
