I'm wanting to install new valve springs on my 87 with 128 heads. I'm putting 1.6 roller rockers in and the tech at Summit told me that thier brand valve springs @ 120 lbs. would work. The FSM shows closed pressure @ 76-84 lbs. I'm worried that the 120's are too much for my cam. Any suggestions on which spring kit to run with stock valves?
I just bought and installed a Com Cams complete kit /springs,1.6 rockers,pushrods, seals, sold by ecklers. I didnt want to have to guess and figured if they were putting their name on it, it they probably already knew it worked. It is exceptionally good, the same kit from Comp cams would have cost bout $100 more . with the newly rebuilt 3rd design injectors from FIC installed at the same time, my car is a pleasure to drive.
Hyd rollers generally work best with between 80-150lbs of seat pressure and 300-400lbs open pressure.
The FSM recomendation/specs are for the stock cam and the stock rocker ratio.... Those recomendations go out the window when you modify things.
With a stock cam running 1.6 roller rockers, 120lbs seat pressure would be fine and not hurt anything.
You have a number of choices. You don't give a PN for the Summit spring but I am guessing it's a 1.250/1.265 OD spring orginally intended for limited class oval track racing. They work fine in hyd FT, mech FT and mild hyd roller applications like yours.
Howards Cams sells this similar spring that will work also for you.
summit # 174001 and they're on sale, so as the wife likes to say, I'm saving money!
Those springs will work fine. The Summit tech guy can't read, as the spec sheet says the spring sets up at 1.700 (stock SBC) and has 104-116LBS and is good to .490 lift.
Your 87 L98 should only have .431/.443 lift after the 1.6 rockers.
