Help!
Old Apr 12, 2002 | 02:31 PM
Corvette0096's Avatar
Corvette0096
Default Help!
85 corvette, Dropping in a zz4 and there are no egr passages on the zz4 heads. If i put the egr on anyways will it trigger a check engine light?
Old Apr 17, 2002 | 12:47 PM
Corvette0096
Default Re: Help! (corvette0096)
Some one?
Old Apr 17, 2002 | 02:41 PM
Hendej's Avatar
Hendej
What triggers the EGR error is a temperature switch in the EGR line. The ECM opens the EGR, then after a while expects to see the temp switch close indicating exhaust flow. You could either reprogram to eliminate the test, or just move the temp switch close to the exhaust. Disclaimer: This info is from an '86 set up.
To Help!
