Loose Tilt Steering wheel!
Old Feb 18, 2011 | 08:30 AM
C4vettrn's Avatar
C4vettrn
Default Loose Tilt Steering wheel!
The pins were tightened up once and it got alot of the slop out but it's coming back. Is there a parts kit out there to fix this specific problem these tilt colums have? THANKS for any help/info.
Old Feb 18, 2011 | 08:49 AM
oldalaskaman's Avatar
oldalaskaman
most of the venders carry them
Old Feb 18, 2011 | 09:50 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Maybe this will help:
http://domesticmisfits.net/forums/viewtopic.php?t=124
Seems to be well documented with plenty of pics.
Old Feb 18, 2011 | 06:18 PM
Gear Jammer's Avatar
Gear Jammer
Active Streak: 90 Days
What you really need is both the upper tilt housing and the lower tilt housing (the two halves that are connected via the pins). Both housings wear out. And the General no longer sells new housings.
Look up Corvette Steering . Com. He has them as NOS, but be prepared, it aint cheap to get both housings.
I just replaced the housings on my 91 and I couldnt be happier.
Ive been meaning to post up the repair operation and my thoughts on this repair, so look for my posting in the next few days about tilt steering pins.
john
Old Feb 18, 2011 | 09:26 PM
C4vettrn's Avatar
C4vettrn
Default Thanks!
This would be a very helpful post Thanks!
Old Feb 19, 2011 | 12:58 PM
jeffp1167's Avatar
jeffp1167
This was a great pictorial ... My 90 has a lot of slop so need to do this reapir before I use it. ... thanks for the link
Old Feb 20, 2011 | 01:00 AM
tpi 421 vette's Avatar
tpi 421 vette
It's usually the 4 bolts coming loose is the problem. The older GM cars had 3 torx headed bolts that had the same problem. Most of the time, just tightning the bolts fixes everything.
To Loose Tilt Steering wheel!
