oil pressure sender
Old Feb 18, 2011 | 10:14 AM
pubble's Avatar
pubble
4th Gear
Default oil pressure sender
would like to replace oil pressure sender.the one that tells pressure # in dash. i think its the one with one blade connector at the end .this is on a 1988 coupe automatic.thanks.
Old Feb 18, 2011 | 10:38 AM
Sandpiper59's Avatar
Sandpiper59
It's behind the distributer, ignorant spot to get at. Can't say for sure which of the 2 sensors you'll find there is it, but if you have your new one in hand,,, One is a main sensor and one is a switch for limp home mode I believe.
Old Feb 18, 2011 | 04:57 PM
nutz4c4's Avatar
nutz4c4
Two ways to do this. You can pull the distributor or pull the wiper motor.
Old Feb 18, 2011 | 07:34 PM
rodj's Avatar
rodj
Is the single wire unit.
Two wire unit is the fuel pump switch
Old Feb 19, 2011 | 09:40 PM
Square's Avatar
Square
I pulled the wiper motor when I replaced mine. It was a couple of years ago, and I recall that I was able to complete it in a single afternoon (I am not a mechanic), and while I found the location to be annoying, it didn't leave any seriously painfull memories (unlike other parts of my 86').
To oil pressure sender
