what sensor is this
Old Feb 20, 2011 | 06:58 AM
ndanl's Avatar
ndanl
Default what sensor is this
hello,
can somebody tell me what sensor is this, that has one wire and is located between cyl 1 and 3 ? car is 91 vette
thanks
Uploaded with ImageShack.us
Old Feb 20, 2011 | 07:03 AM
87 vette 81 big girl's Avatar
Originally Posted by ndanl
hello,
thanks
Not sure if you have a L-98 or LT-1 engine there.
I know its a Corvette because you have Aluminum Cylinder heads.
Only Corvettes had Aluminum heads in that era or time frame.
If an L-98, thats the coolant temp sensor for the dashboard coolant temperature gauge.
Old Feb 20, 2011 | 07:07 AM
ndanl's Avatar
ndanl
this is an L-98, ok then it is the temp sensor for the dashboard gauge,
thanks
Old Feb 20, 2011 | 07:41 AM
braeburn22's Avatar
braeburn22
Hi
It may be the coolant sensor for the aux fan, if it is the same as my 89, the dash sensor is on the other cylinder bank between 6 and 8
To check earth the wire with the ign on, if it is for the aux fan the fan will run if it is for the coolant sensor the dash gauge will go to max
Old Feb 20, 2011 | 07:45 AM
rodj's Avatar
rodj
89 was last year of Aux fan in front of radiator.
'90 + have dual fans on rear , both controlled by the ECM
In '90+ L98's , the hole in question had a blank plug with a square head
Correct location if it was a '84 - '86E engine
It is the correct type unit for the gauge ; just in the wrong location for your year model.
Maybe the heads have been off and they couldn't be bothered to remove the plug to swap over
Does wiring to it appear stock ?
What have you got in the same hole on pass side head between # 6 and 8 cyl ?
Old Feb 20, 2011 | 07:46 AM
Hi
You may be right. I have an 87 vette with a MAF equipped TPI and star wars dashboard gauges.
I remember the dash coolant temp gauge wire on my 87 being a 16 gauge GREEN wire.
Old Feb 20, 2011 | 04:37 PM
kmhene's Avatar
kmhene
It looks like a knock sensor. That wire is bad. It has a plug on it.
I am going to replace mine and thats exactly what it looks like to me.
Kevin
Old Feb 20, 2011 | 07:18 PM
vetteoz's Avatar
vetteoz
Some people should really leave the keyboard alone and not take wild guesses or at least wait until the medication has worn off
Sensor shown in post #1 looks nothing like a knock sensor
If fact ; with the single blade terminal it doesn't even look like the factory Aux fan switch
which has same style connector as the knock sensor
kmhene
Have a look at your block , Pass side ,in front of starter and see if something like this is there
A KNOCK SENSOR
Old Feb 21, 2011 | 05:34 AM
kmhene's Avatar
kmhene
Wow,excuse me. I have an 84 and thats exactly where the knock sensor is. And mind does look like that. Sorry to misinform you if I was wrong.
I can see why its the same people posting on this site.
You bad mouth other people when they repond to something so they stop.
Well it works. I'm done here thats for sure
Old Feb 21, 2011 | 06:39 AM
lt1396corvette's Avatar
lt1396corvette
kmhene
A KNOCK SENSOR
Pissed him off huh!
Old Feb 21, 2011 | 08:28 AM
vetteoz's Avatar
vetteoz
I have an 84
Exactly
OP stated his was a '91
Very little about your '84 CFI engine is the same as a '91 TPI engine except for Chevy on the rocker covers
and the dist at rear
Who told you, your unit is a knock sensor?
Yours would be the only '84 with a knock sensor in the drv side head where every other '84 has the gauge sender unit?
No .
I correct people that put up miss-informed , bad or plain out wrong info.
Just because YOUR year model has something , doesn't mean another year does
Even worse when you make a blanket statement like you did that is wrong for ALL years`
Post up a pic of your knock sensor in your head to see if others agree with your opinion
Old Feb 21, 2011 | 08:46 AM
vetteoz's Avatar
vetteoz
Oh looky ;
a picture from the FSM showing were the factory put the knock sensor in every other '84
when it left the factory
Maybe yours was special order?
To what sensor is this
