1990, 388, 9:1 comp, AFR 195s ,Comp 280xfi, superram,30lbs, 58mm t/b, no emissions or egr, pcmforless chip.
I got it running and changed the oil, it is idling at 1,100 rpm. It stalls sometimes when idling. It also smell like it is running rich, and it is backfiring once in a while when idling and on deceleration.
When I took it for a ride to set the rings I gave it half throttle and it would surge badly from 2000 rpm and up. The check engine light is also on. At about a 1/8 throttle it wont surge.
It is throwing a code 24, 14
Also it will not surge when I rev it up in neutral.
I only drove it around the block, I dont want to continue driving it and ruin the engine.
Any advice you can give would help, I have spent everyday for over a year on this build. Thanks
For the TPS to be off, there would have to be an issue with the sensor, the wiring, or the minimum air screw
I never set me IAC and I just read the reading off the tps was .41. I am going to set my IAC the TPS.
I also check my wires and they are good. My timing is also set to 6 with the timing wire pulled.
I removed my plugs and they are very fouled. Perhaps as a result of all of the oil I coated the cyl with prior to installing the heads. I just purchased new plugs a hour ago.
I found the breather hose going from the valve cover into the t/b was very loose perhaps causing a leak. I will cut it back and make sure it is secure.
Thank you for all of the replies so far. And any other replies will be greatly appreciated. Thanks Walt
I have not had a chance to start it yet. It is pretty loud and I have to wait for the daytime.
I found out my 90 does not have a adjustable tps. I am unable to get it above .41 closed and 3.45 at wot. I have tried two seperate tps's with the same result. Is this normal? Thanks for the replies.
no it's not normal...first what is the idle rpm in the tune? Get it to operating temp. set the IAC counts to +/-40, and recheck base timing to 6*. I would also be looking for any vacuum leaks. If it is still that rich then probably the 02 is fouled out by now, the tune needs to be worked more, and it will run poorly.
Called pcmforless today and had them go over the intial data i sent them. They read it back and it checked off good. They said my idle should be about 1k with the cam i am running.
The car runs so rich I cant get it to idle with the iac disconnected.
I replaced the CTS and I still keep throwing a code 14 as soon as it fires. Code 14 is (high temp indicated) on the coolant temp sensor (cts).
Do you think if the car believed it was overheating it would go into limp mode causing it to run so rich?
I set IAC using a scanner or data master to around 40 cts. at operating temp and at idle in park. When you do it this way there is no need to disconnect the IAC.
I replaced the CTS and I still keep throwing a code 14 as soon as it fires. Code 14 is (high temp indicated) on the coolant temp sensor (cts). Do you think if the car believed it was overheating it would go into limp mode causing it to run so rich?
It's possible, but I don't think it would go into limp home based on that directly. If the CTS is faulty that can cause excess fuel because some of the fueling tables are based on coolant temp.... of course depending how Alvin has those tables tweaked.
I would also look at the 02 mv. on the data master after the car enters closed loop. If you see the m.volts saying the same with little or no cross counts, that will indicate a trashed 02 sensor and also cause the car to be excessively rich. Typically if the tune were rich to begin with, it will trash an 02 sensor.
Not trying to be a wiseguy but there are two coolant temp sensors on my LT1. The one in the waterpump housing is the one that throws the code and it would be responsible for an overich condition. Hang in there it took me about a month to get all the bugs worked out of my new 383. Also check and recheck the plug wires. A missing cylinder will cause the whole bank to go rich.
Hey Walt, it's good to hear you've got it together and running now, hang in there & you'll get sorted out! I agree w/Mick, I had a bad O2 and my car wouldn't run worth a damn no matter what I did. Are you logging? If so the cross counts will tell the story.....no matter what you do it won't smooth out with a bad O2. Congrats brotha stay the course, your getting close
