Moog upper ball-joint finish
Old Feb 20, 2011 | 07:12 PM
RUU's Avatar
RUU
Default Moog upper ball-joint finish
Can anyone comment on how the "brownish-bronzy" finish of the Moog upper ball-joint tops holds up? I don't mind the industrial look of them out of the box, I just don't want them to start rusting after they are installed. I'm debating whether to spray them with black semi-gloss to avoid that potential problem.
Thanks.
Old Feb 20, 2011 | 07:17 PM
oldalaskaman's Avatar
oldalaskaman
I vote , clean and spray, 5 minutes work, no worries, specially if they salt the roads there
Old Feb 21, 2011 | 10:57 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Mine came black and after a couple years they are still the way they were when I put them on.
Old Feb 21, 2011 | 01:30 PM
383vett's Avatar
383vett
Keep them covered with grease. They'll look black and never rust.
Old Feb 21, 2011 | 02:49 PM
RacerX70CC's Avatar
RacerX70CC
I paint them with Rustoleum black hammertone paint...
Old May 21, 2011 | 01:31 AM
RUU's Avatar
RUU
Just to follow up, I decided to paint them satin black as there were a couple of spot welds on the top plate that looked like they might rust. FWIW, the lower Moog BJs that I installed 2 summers ago have the same finish and still look fine (even though you can't see them without looking underneath).
Thanks for the replies.
To Moog upper ball-joint finish
