need cam reccomendation
http://www.youtube.com/watch?v=0b5mW2QF6H4
Mama said ...We didn't know we were leading the green revolution... we were green before green caught on with the pretty boyz in town...."I recon".. "yep"
and by the way..
We ain't really sure if we know what a smog test is....???? Sniffing exaust is what you hoped your mother-in-law did.. seems sorta californish to us... you know with all them thare fancy lights an all...
Dont tell them law dogs in Noth-Caroliner we using big cams downtown on saturdee nights if you get our drift. Yep..
Yep... sorry.
I am using the Comp's Cam 8-305-8 grind number 276-hr14 and I am very happy with it's performance as well as street manners. This is an hydraulic roller cam with spec's: 220-230 @ 50, 510 -510 114 LSA. My 1.6 to 1 Crane roller rockers probably give it a bit more lift. The valve springs were chosen by AFR when I told them my spec's. It idles very nicely with just a hint of lope, and response is instantaneous. It pulls hard all the way to about 5500, (I shift there, but it will still pull to 5800) and I couldn't be happier with the selection.
We are still in the tuning stages by running it on the street with the lap top and tuner in the passenger seat. I did run it on the 1/8 strip Saturday nite for the first time and my best of 4 runs turned an 8.012 e.t. at 88 mph with a 60 ft. of .190. (my tuner says he can get a couple of tenths lower with some tweaking and I have got to get out of the hole better to lower the 60ft. times. I will be experimenting with tire pressure next time out. Once we get it fully tuned I'll be heading for the 1/4 mile track at West Palm Beach. (formerly Moroso)
Best of all, was the fact that I turned a lot of heads that night, and ate 2 Mustangs and a Camaro big time!
Who turned you on to this? and did you try something else before?
I noticed from driving my 383 Vette for over 2 years, reving it to 6,000+ rpm is simply too much winding, I like to get things done in the first 4,000. we'll see.
do I have to change the oil after the cam change and do they have to keep the push rod in the same place and do they need to put assembly lube on the cam?
Just trying to put some levity into it.
It seemed you were asking questions that you already knew the answer to.... and thats OK. ..! I like the focus and passion.
It reminds me of the guys I meet at the minature aircraft field who don't know I have a pilots lic. the "expert" conversation is impressive...if you were a blind man.. or... a time in Wy,, with a few friends that included Andy Petree... and this guy at our dinner table tried to tell Andy with all conviction he "Flat footed" Charlotte in a Cup car.... now that was funny.... until he figured out who Andy was... and now for the rest of the story... it was in a Petty driving school car... Lets just say they are a little off the Sunday pace.
But you should really check out the link...Life is full of interesting facts.
Oh, a tree with no branches does grow tall!
Last edited by GREGGPENN; Feb 25, 2011 at 12:32 PM. Reason: Didn't understand context of comment.
I doubt "moonshiner" read you wanted a smaller cam before he posted for you to buy a bigger one. Following that up with moonshine talk (and youtube) seems like a reference to the earliest need for fast cars. In the prohibition era, moonshiners HAD to be faster than the police to keep from getting arrested. Since it was the early days of the automobile, racers often went to the moonshiners for advice.
The was a recent documentary on TV about this.
[Semi-] funny post and story -- but no practical value for this topic.
You posted, a comment about moonshining, and right after that I compared it to Ebonics as the grammar in both those colloquialisms are similar. So now I have a reference point.
When I wrote "you" instead of his, I did not want to accuse any particular person, (bad taste), I used "you", as a stand in for "one" which I think in English grammar is acceptable albeit nebulous.
The vague nature of this sentence construction resulted in the misunderstanding only because this is the internet and not vis-s vis.
yes I am aware of the moonshiners hot rodding cars to get away in the day, for the good guys the P71 option for the Ford Crown Vic is as wild as they have gotten, at the end of the day private cars will always out run public servant cars.
there more to just speed in a chase anymore these days, camera, PIT, traffic, you name a few....
I think you should consider the cost of replacing springs vs the cost of replacing a cam. You can install several sets of springs for the cost of one cam swap (unless you've learned how to do your own work).
I think the cam Stevie is using is a great choice. The lobes are milder, the duration is less, and there is more overlap. All of these address what you might have done at the beginning of your project.
Instead, you built a targeted application of a cam and heads that pull to 6500. You built an application designed to make it's best power in the upper rpms. Both the cam AND the heads you chose ignore the lowest rpm performance. I think you have to live with that.
By swapping to his cam, (Brian is right) you won't notice THAT much difference -- especially if you're looking at something like the 220/230 cam Steve's has. You'll probably shift your powerband down potentially 500rpms. Would you be surprised if, at any given rpm, the overall power change may be less than 15 ft/lbs (or HP)? That's hard for most people to FEEL. I believe that's why Brian said you'll end up disappointed. OTOH, a 214 or 219 single patter cam may be sufficiently smaller where you might feel the difference.
FWIW, I chose the 195s to get higher port velocity out of a larger head. (My understanding is the AFR195 is the head that comes the closest.) Combined with my 214 cam and a superram-like intake, my goal was to get near factory manners with maximum mid-range performance. The result still requires an additional 100rpms at idle to compensate. (That's either a result of the bigger overlap [than stock] or the larger intake port [than stock].) For someone who swapped to an automatic, you wouldn't even notice the issue. If you did, just raise the idle a hair, it should want to pull out of the gate. You may be able to throw more low-rpm timing at it too. With the 220/230 cam, I can't imagine you'd see much improvement in MPG. You driving habits would affect it more!
While I see you like to investigate possibilities, you're doing too much after-the-fact. You're build is complete. Swapping cams ALONE probably won't make you jump with joy. 180's paired with a cam in the teens would make a difference. It's what most of us would recommend to a guy who said he wanted to make power by 4k rpms. If you swap to a FIRST intake, you'll get more torque [lower] if that's what you want. I also think you'd feel more of a difference. Think this over VERY carefully. Make sure your springs are really bad and don't put the cart before the horse.
I don't know if you ever figured it out, but you swapped to an automatic because you weren't happy with a ZF. IMO, the problem was you paired an unsprung clutch with a SMF. That by itself was ill-informed...badly ill-informed.
I suggest learning more about cams before deciding you need a new one. I guarantee 95% of builders would choose a cam of similar duration (to your cam) for a 383. If you still want to change, try 1.5 rockers first. People are always looking to buy 1.6 rockers.
I can do the work, but my housing complex is a no go... for that anyways, removing engines and transmission is out of my ability.
sounds like a good recommendation, still learning, just my shop had their own ideas of what was right, and I was at their mercy, I should have left it a stock rebuild. They wanted me to spend money with them to make it a 396 after the engine was built,( I was getting poorer and poorer at the time so I said no) trying to hit me up for the money, I went to them first and he never called back so I went to Ron, had my differences with him at the time( we are buds now).
My shop insisted I go Super ram, so I sold off the TPI/ASM runners/ Cusinart ported stock base. and bought what everyone at third gen felt was the best lobes in the business, they are infected with the 280 xfi over there.
Since Kevin was going to do the tune (CA close to me, lets just say his tuning left much to be desired as well, so I "HAD" to by my Moates stuff and learn how to do it, with some help from my shop who does later year tuning and was new to TPI, they had the experience but I had to access the bins), (M7 bowed out of my tune as he and Ron was a package) I went with his ( Kevin)cam recommendation, I researched a little, I knew little and still know little.But I became a 280 xfi owner since then
6500 is a bit optimistic given the cubes and the cam's application is for a 350, I took the power band down a notch for my size engine, that was the consensus of the investigation at the time, and frankly some believe the entire packaging behaves greater than the sum of it's parts, and my bottom end is not compromised, I do have a 2300 stall i wish was a 1600 stall though. I don't have dyno's or time slips but I felt and still don't feel a 5700rpm ceiling imposed by the Super Ram and read elsewhere others have experienced similar driving sensations. This is my debate and theory, experts will laugh at me. and they do. AFR street eliminators where a no brainer, if it "ignores" anything so be it.
Point noted, I don't want an exercise in futility, if 15 horse give or take and I can't feel it, I'd rather save my money, I may be a lousy tuner , since I am getting 12 mpg consistent for the whole time I have had this motor, that said the car runs like a Rolex, gold with diamonds.The LPE 219/219 intrigues me, but that was made for a 350, although it is a bad *** in a 383, so I have read.
I love my auto, I live in the most congested roads in the country and the stick was a real pain, It started when the shop (I won't mention any names about that), decided to internally balance my rear of the engine( stock was external rear),they zeroed my dual mass flywheel, well before my shop put it in, it oozed and oozed and oozed, even after I cleaned and cleaned and cleaned, it was mortally wounded and since, I read you or rather one can not machine a dual mass lest it damages the mechanism. I opted for the spec, and I search and search and read about sprung hubs, I ordered 2 from summit on 2 separate occasions, they did not fit, and I was running out of time my shop was antsy and had to mount the engine stat! needless to say the unsprung hub disc made it's way in my install, and we all know what that meant...
I grow up believing every human has the right to change his or her mind, and nothing on earth is permanent, if a person has the desire and the means to improve or change something, it is his prerogative, To study to learn and to investigate without change is also one's prerogative. That said hindsight as we all know is 20/20 woulda,coulda, shouda, without A, for comparison, we would not want B. so ,my wanting 4,000 redline ( I was exaggerating did I say that? how rediculous to hear it reverberate back to me, hope no one took take seriously or even gives a flying rats azz)
I was not unhappy with the ZF, I like the bragging rights of the "Black freakin Tag" but my commute in my daily driver says other wise and I am still please with my decision. I am always poorly informed, but strive to improve, by being in the best place on earth...here
However, the rocker ratio amplifies that shape by 1.5 or 1.6 times. There will be more acceleration with the higher rocker ratio. More importanly, the spring compresses more. While I'm no expert, I'd bet that the AMOUNT of spring compression is more responsible for wear rates than speed of compression. (Think about a springs on a milder cam running at 6k rpms for 100k miles).
I don't always agree with Jeremy. I think lowering your ratio would help the springs last longer. I wouldn't be surprised it it doubled expectancy.
One other thing to consider is my broken spring suggestion (and when your heads were purchased). IIRC, AFR changed spring vendors about 2yrs ago. It could be your heads included the prior vendors springs -- which may have their issues. (Don't quote me on this though...A lot has happened in 2 years. I might not remember correctly.)
Comp relayed the same argument to me. They said not to use 1.5's with an XFI cam since they were engineered to work with the higher ratio. That seems hard to believe, but I can't refute it. It might be your best supporting argument for the cam swap -- if/when you determine worn springs that are part of a good batch.
I know people run stock SR's and ported SR's. Will a ported SR mimic a cam change? are there any downsides to radically gouging metal from the SR? is yours ported to achieve those rpm levels?
mine is stock and it goes there rather readily, it's nothing to it, it hits the fuel cutoff abruptly , set at 6300,(since my lame atari dash tach is 1500 rpm behind in it reporting duty)
another reason I fear to rev it hard, I sold the shift light when I swapped to the automatic.
I can't quantify my combo, but the AFR's are supposedly at the time, were some high tech pieces and so was the xfi cam lobes, perhaps the combination cannot be figured on paper, but only where rubber meets the asphalt.
mine is stock and it goes there rather readily, it's nothing to it, it hits the fuel cutoff abruptly , (since my lame atari dash tach is 1500 rpm behind in it reporting duty)
set at 6300, I can't quantify my combo, but the AFR's are supposedly at the time some high tech pieces and so was the xfi cam lobes, perhaps the combination cannot be figured on paper, but only where rubber meets the asphalt.
I had my SuperRam base and runners Extrude Honed years ago and it really opened it up internally. I am running it on my 406 with a 230-240 cam and it goes through the traps at 6600 @ 127. I think these SuperRams can be made to breathe really well and still provide good low-midrange torque.
I tried to visualize the float prone zone/ event and I think you nailed it.
When a person sitting at AFR speaks with authority with his speed of thinking I fell into the trap that his words were gospel and I became gullible.
Now that I think of it, over compressing a spring at the end of it's travel were it has the most stored/rebound energy, when contrasted with not compressing the spring to the limit and the stored energy at that zone IS different, even less.
your theory holds water, The cam, I read spins 1/2 the crank speed rpm and If one eases into the throttle on a street car that can slow the rate in which any ramps will be introduced, correct?
I see the light hallelujah!
my heads came first, then I bought the springs then I sent the springs back for a little credit, in Jan 2009
who cares if it's 1.5 or 1.6 but me
