need cam reccomendation
I had my SuperRam base and runners Extrude Honed years ago and it really opened it up internally. I am running it on my 406 with a 230-240 cam and it goes through the traps at 6600 @ 127. I think these SuperRams can be made to breathe really well and still provide good low-midrange torque.
230/236 on a 383 hmmmm...
I heard extrude hone's function is to smooth, I call around here and they said no significant amount of material is removed, a different approach, but aerodynamics related I presume.
No Siamese? I heard that was the ticket or maybe not....
Dr J out here in Orange Ca. welds material on to the base to re-contour the attack angle
so frankly there are 3 or more ways to do up a super ram, frankly is it worth the time and money for what gains?
my guess the bigger the motor or the more you want to wind it the better flowing it needs to be
C4 of Year Winner (appearance mods) 2019
There's probably no downside with your 383/AFR/auto combo. (Wait! You'll want to run it into the higher rpms even more often!
Could that require even more spring swaps?
)IIRC, the Atari tach can be off if the tach filter is missing or malfunctioning. You might check for it's presence (or replace it) if you want a better reading.
I feel over cammed, 230/240 on a 406.
Many don't consider this cost effective when you can swap to a miniram (or FIRST) to get a HP (or TQ) increase without spending much extra. (The assumption would be you'd trade/sell your SR with very much lower net out-of-pocket.
FWIW, the FIRST has that better "attack-angle" Dr. J refers to.
Dont think you need to do all that science project cut and weld to make it work good. If you have the time and funds it can be fun to play with but an agressive port job will wake it up imo. Thing is you can only get the runners so big especially where it goes into the base, have to make it seal too.
so can I have someone slap these in a call it a day?
so would these eliminate my need to buy new springs?
http://www.airflowresearch.com/index.php?cPath=75
