Roter removal - any tricks?
Old Feb 23, 2011 | 04:54 PM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
Default Roter removal - any tricks?
Pulling the original front rotors off a 95. Caliper and bracket are off. Rotor is really stuck on the hub bearing flange. I had soaked it with PB Blaster last night and tried to work it off with a dead blow hammer, but it won't budge. Only thing I haven't tried is heat.
Any tricks, suggestions or guidance to steer me in right direction would be appreciated. TIA.
Old Feb 23, 2011 | 05:06 PM
84vette96's Avatar
84vette96
If you have all of the fasteners off and tried hitting with a hammer, heat would be my next step. Just be careful not to overheat the hub assembly and melt the seal or burn the grease inside of it. I would try to heat a little then hit and repeat until it pops off.
Old Feb 23, 2011 | 06:39 PM
dizwiz24's Avatar
dizwiz24
important question:
are you hitting it on the back side (engine side) or on the front side.
You should be hitting it at the top of the front side only.
Hitting it on back side will not dislodge it.
Old Feb 23, 2011 | 07:03 PM
93Rubie's Avatar
93Rubie
First of all, put down the dead blow and get a real hammer. I have a small 3lb one for such jobs. Beat the snot out of it with that and if that does not work, try some heat. I have beat rotors off in pieces before, that is one way to do it.
Old Feb 23, 2011 | 07:27 PM
dizwiz24's Avatar
dizwiz24
except dont beat it on the wrong side !!!
Old Feb 23, 2011 | 07:33 PM
383vett's Avatar
383vett
Originally Posted by dizwiz24
important question:
Wondering why not. I've always used a 2X4 and a 4 lb mallet on the backside.
Old Feb 23, 2011 | 07:42 PM
Sandpiper59's Avatar
Sandpiper59
If/when you do heat it, do so to the rotor only, no heat on hub, you're trying to get the rotor to expand. Agreed with comments on a real hammer, it needs a sharp ringing hit to get it to crack free from the hub.
I'll assume this is not original rotors at that age, but if they are, they may have factory speed nuts on 2 or 3 studs done at factory. They are thin hardened spring steel and can go un-noticed with rust. They are used at factory to hold rotor onto hub without wheels or wheel nuts.
Old Feb 23, 2011 | 07:46 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Good luck! This sounds like the problem on my new to me 97 F150. The front wheels would not come off! I was able to kick the driver front off, but the passenger side was not moving. PBblaster, deep creep, kroil, beating the snot out of the front and back, breoke a 2 jaw puller, finallya bit of heat and beating the snot out of it got it to release from the hub.
For your rotor try beating it at 12 oclock from the front, rotate 90* repeat. after a couple of revolutions apply some heat to the rotor. Try not to heat the hub. then repeat the beatings. Then heat, then beatings. It will eventually come off. When it does take a wire wheel on a drill and some sand paper and clean the mating surfaces.
Throw a bit of anti sieze where things meet together avoiding the studs.
Good Luck!
Old Feb 25, 2011 | 10:38 AM
anciano's Avatar
anciano
Snce rotors can get glowing hot under hard use, it's hard to imagine that you could get TOO MUCH heat on them. There aren't many "stuck-on" problems heat can't cure. I'd cook 'em good if it was me...but (disclaimer) I'm not known for mechanical prowess.
Old Feb 25, 2011 | 06:17 PM
miker2's Avatar
miker2
i use an air hammer. the vibration loosens better than the biggest hammer.
Old Feb 26, 2011 | 12:28 AM
1991ZR1's Avatar
1991ZR1
When I couldn't get my rear rotors off by hitting with a hammer, I tried using a 1" x 1" piece of wood. Wedged it in behind the rotor against something, probably the hub, and gave it a tug. The rotor came right off.
Old Feb 26, 2011 | 08:35 AM
78pacer's Avatar
78pacer
X2 on the air hammer. I've used that in conjunction with heat on steering knuckles\hubs and rotors with 100% success. The worst had to be my '97 Expedition which uses the same set-up as the OP's F150.
Before using the air hammer, I had a 16 lb sledge and was whacking the hell out of it until I cracked a huge chunk of the rotor off. That's a feeling of commitment..*S
Mike
Old Feb 27, 2011 | 05:02 PM
jimmymack's Avatar
jimmymack
Thanks for all the guidance guys. Rear ones came right off with a little wiggle, the fronts were a PITA. Used heat as suggested on them and banged with a piece of wood as buffer, they finally came off. Needless to say, put some anti-seize on for the next time.
To Roter removal - any tricks?
