L98 timing
Old Apr 13, 2002 | 01:14 AM
DADDY D's Avatar
DADDY D
Default L98 timing
what do you set your time at for best performance and horsepower on 86 vette
Old Apr 13, 2002 | 01:22 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: L98 timing (DADDY D)
For 85 - 8deg. advanced.
If you check out prior posts, most setups are between 6 to 8 deg. advanced.
:chevy
Old Apr 13, 2002 | 03:33 AM
Bill Reid's Avatar
Bill Reid
Stock chip? Stock induction and cam?
6 degrees... as prescribed from GM on the drivers side of your top radiator cover :)
Old Apr 13, 2002 | 04:03 AM
OrangeC4's Avatar
OrangeC4
Default Re: L98 timing (billreid1@***.net)
:yesnod: "THATS CORRECT SIR!!"(in my worst Ed Mcmahon voice)
Old Apr 13, 2002 | 10:07 AM
DADDY D's Avatar
DADDY D
Default Re: L98 timing (OrangeC4)
my car is far from stock it has right many mods
Old Apr 13, 2002 | 12:49 PM
OrangeC4's Avatar
OrangeC4
What do you have done to it? You can't put a teaser like that and tell us at least some of what you have done.
Old Apr 13, 2002 | 01:03 PM
DADDY D's Avatar
DADDY D
my motor has been rebuilt it was bored .40 over 52mm tb,flowmaster mufflers, slp headers, no cats, k&N filter, open air lid, 3.73 gear, hypertech chip, cam .444/.444, heads ported and polished, and dry shot of nos if i could ever get it to work a custom chip and a set of 1.6 roller rockers comning soon
Old Apr 13, 2002 | 01:45 PM
tpivette89's Avatar
tpivette89
i keep mine at the factory setting of 6 degrees
Old Apr 13, 2002 | 01:51 PM
AS84's Avatar
AS84
Default Re: L98 timing (tpivette89)
advance it until it pings and then pull 2-3 degrees out of it. I run my modded 90 at 11
Old Apr 13, 2002 | 11:17 PM
DADDY D's Avatar
DADDY D
Default Re: L98 timing (AS84)
thanks i will try that
Old Apr 13, 2002 | 11:25 PM
scorp508's Avatar
scorp508
For me personally 9.5 has been the best, yet I also have not tried higher yet.
Old Apr 13, 2002 | 11:52 PM
Bluevette85's Avatar
Bluevette85
Setting the correct timing assumes that the Harmonic Balancer hasn't slipped and that there is no slack in the timing chain.
Old Apr 14, 2002 | 03:07 PM
DADDY D's Avatar
DADDY D
Default Re: L98 timing (Bluevette85)
timing chain and harmonic balancer only has about 30,000 miles on it i just had the motor rebuilt about a year and a half ago.
To L98 timing
