skip shift???
Old Apr 13, 2002 | 01:32 AM
MattS4313's Avatar
MattS4313
Default skip shift???
my freind has a 1996 z28 with a 6spd... how does he get rid of it???
Old Apr 13, 2002 | 01:52 AM
VAHROOM's Avatar
VAHROOM
Default Re: skip shift??? (MattS4313)
Summit, Jegs and a few others have a connector that you place in the harness going to the transmission to eliminate this. I know in the older cars you could just unplug it. The newer cars require a diode in there somewhere to prevent a TC from being generated.
Old Apr 13, 2002 | 03:04 AM
MattS4313's Avatar
MattS4313
Default Re: skip shift??? (90_roadster)
can you just cut the wire?
Old Apr 13, 2002 | 09:32 PM
VAHROOM's Avatar
VAHROOM
If they are like the Vettes, there will be a trouble code generated if you just cut it or disconnect the connector.
Old Apr 13, 2002 | 10:49 PM
STL94LT1's Avatar
STL94LT1
Unplug the CAGS (skip shift), stick a 2.2k ohms resistor in the connection running to the car, and tape both plugs with electrical tape.
The ohms resistor will keep the car from flashing a code. The resistor can be purchased a Radio Shack 5/$1.
To skip shift???
