Track width meaning axle to axle-not wheel to wheel. Right?
You physically made the half shafts longer (wider)?
Thanks,
Steve
P.S. Looks Great!!
I think track width is measured to the centerline of the tire. So if he went with way wider tires (which he did) then the half shafts could be longer and the track width could be narrower. Seems strange but he added 4.5 inches to the tire width on each side (I think).
Thanks,
Steve
P.S. Looks Great!!
I changed to early knuckles which are 3/8 narrower. Did this because we need the late knuckles at the shop for other reasons. All in all by just putting a wheel on with spacers to do some measuring without a tire and how I had it pictured to look, without it being lowered.....I moved the wheel out 3/16 on each side to be happy. I am having half shafts made. Thats not much and most would never even notice, but I do. So I missed it by 3/16...not to bad for the 1st time. Stock control bars will not work and the swaybar is a very tight fit.
Yes I moved ever thing including the control bars. Even moved the rearend up in the car. Its lower and still works as it should.
top notch build..and the car looks great!
I have a couple of questions for you.
I see that even with the rear moved up in the car it appears in the pics to be starting with some neg. angle on the half shafts. Do you think that will present any issues ?
I imagine you went has high up as possible without (cutting up the rear of the car) going below zero with the drive shaft or ?
If wouldn't mind, I would like to see how the low mount for the alt. for the alt. was accomplished.
TIA
[QUOTE=COPO;1577202381]I changed to early knuckles which are 3/8 narrower. Did this because we need the late knuckles at the shop for other reasons. All in all by just putting a wheel on with spacers to do some measuring without a tire and how I had it pictured to look, without it being lowered.....I moved the wheel out 3/16 on each side to be happy. I am having half shafts made. Thats not much and most would never even notice, but I do. So I missed it by 3/16...not to bad for the 1st time. Stock control bars will not work and the swaybar is a very tight fit.
I understand-Thanks COPO! Good luck with the rest of the build.
TIA
Most think that the half shaft should run up downhill. Its really how the hs and camber bar work together in relation to the control bars and toe bars. They are the ones that control the movement of the knuckle or we could say keep it in place during travel. Another way to think of it is a upper and lower a arms. the upper control bar and half shaft being the upper a arm/ lower control bar and camber bar being the lower a arm. If looked at that way consider where most mount the coil over that is way inboard as compared to in the back where spring rate can be controlled better.
Low mount for the alt??
Thanks for the response...I never considered that. I always looked at it with the mentality of a drive shaft (starting with neg. angle so that under load it can only go to parallel). Reading your statement regarding toe/control bars, what then is needed to better control the knuckle ? (I agree, and like the idea of getting the angle of the coilover changed and behind the h.shafts).
In one of your build pics. it looks like a low mount alternator (or?) on the pass. side. I couldn't tell how you achieved room on that side with the a arm support, rack mount etc. being in the way.
It all starts with the hs. thats the one that cant be changed for adjustment and ride height needs to be known. Take 5 arms with 10 pivot points, make them hold a wheel to the curve of the body roll while pointing straight and putting power to the ground.
Thats the ac compressor mounted down low. Its a bracket we make for or pulley system. Its offer several ways and I like this one the best
Made it outside on its own power. I havent done the front yet. Plans on spending the weedend on that. Only has a eyeball aliginment. But progress is being made.
