SO i installed the new Air pump delete pulley and am now having problems. I think i messed up the engine rotation somehow. When i turn the car on it is fine, but when i hit the gas no matter what gear im in the engine bogs down and also miss fires!! Does anyone have any idea why this is happening? I was under the impression that the delete kit was a direct replacement with no problems and i cant seem to find a thread where any one else had my problem! any help would be appreciated!!
I put the pump delete kit on my car and it required a 1" shorter serpentine belt, the belt would slip when u reved the engine. the new shorter one actually cost less than a stock belt. That could be it.
Belt length has nothing to do with it. I put a 1" shorter belt on mine without any problems. Have you removed all the AIR piping? You need to cap the pipes at the exhaust manifolds with a 1/2" pipe cap. Check all your vacuum lines and cap everything that you removed.
When I did mine I accidentally broke a plastic vacuum line right behind where the air pump was installed. There were two lines that were connected together at a large rubber fitting plugging into some little plastic piece. One of the lines went all the way to the vacuum canister in front of the driver's front tire. The other line (if I remember correctly) turns around and goes to the EGR valve. Check one of those. They may have worked great when they were new, but they kind of suck now. 1/8th rubber line at the parts store works wonders.
I found it!! I forgot that i had changed the power coupler to the smooth one right before I started on my AIR pump Delete! I had unplugged some plugs in the vicinity and not plugged them all back in!
AIR pump delete works great now! All hoses have been removed and everything else capped! Thanks for all the help!! Greatly Appreciated!!!
Do you know the part number of the shorter belt? I put on the smog delete kit and my belt is a little loose.
Gates belts come in 1/4" increments. Have the autoparts guy look up your stock belt and tell him you need one 1" shorter. If it doesn't fit, swap it out accordingly.
I just did the same thing and I am having the same issue but I didnt think it had anything to do with deleting the air pump. So many on this forum have done this with no problems.
Hopefully someone on the forum can give us some answers.
Just to compare our problems, my stumbles when I move the throttle cam on the TB about 3MM. I have a 6 speed and when I drive it it stumbles at the beginning of acceleration in each gear.
Just to be clear when I deleted the air pump I also installed new Delphi injectors from Jon and installed a refurbished TPI intake system.
I posted the post above before I saw this post from you. Please explain what the power cupler is and what plugs did you find unplugged? As you can see from my previous post I did more than just deleting the air pump.
I capped the pipes on the exhaust manifold and also the tube that runs right of the engine back to the Cat at the middle of the car.
I called the pipes on the exhaust manifold and also the tube that runs right of the engine back to the Cat at the middle of the car.
I would love to find my stumble problem.
If you have a 90 or 91 with the polished tpi and the red base, with the K&N air filter connected to the TB you have nothing here that effects you. The power coupler goes to the MAF which you dont have.
However, if you have an oxygen leak on your manifolds, say where the one way valves connect to the air injection system, you just found your problem
I have a 86 and I was told to have it removed from the computer. I had done many other things like cam and headers injectors. So I did send the computer to a place I can't remember ( There name was something like tpis in Minn.) and they reprogramed it for all my changes. I don't know for sure if this is your problem but mine runs and goes great..
You can't do that.
If you remove the a.i.r. system you need to remove it ALL....cat included.
The cat cannot survive without its air supply. The air feeds o2 to the cat so it can lite-off and burn. If it cannot lite-off, it plugs off.
The exhaust gas enter the catylist and cake to its substrate when there is no o2 to allow them to burn and chemically change to water vapor.
Is this by chance an early OBD-II ????
if so the rear o2 sensor if freaking out because the cat is not doing anything. If there is an o2 sensor behind the cat....theres the problem.
I think that 90-91 are OBD-1 and only 1 o2 sensor, but want to be certain.
