LT1 harmonic balancers
Old Feb 28, 2011 | 03:50 PM
C4fan's Avatar
C4fan
St. Jude '10
Default LT1 harmonic balancers
One last thing I need for the stroker is a balancer. I don't want to spend the bucks for an ATI. Mine is not a racer. I do have concerns about the Pioneer. Although I've read a few posts here about them coming apart I've not read one from a person who's failed. This is some of the one's Ive found. Looking for comments on what you have used or other balancers.
Dorman OEM aftermarket replacement $70-85
Pioneer non SFI base model $120 part #872013 requires hub #872015
Pioneer SFI approved $175 part #872043 requires hub #872015
Auto Specialties $150 part #945800 (not sure what diameter or if it requires a new hub)
Old Feb 28, 2011 | 05:38 PM
96GS#007's Avatar
96GS#007
What's wrong with your current one? If it's not broke, use it.
Old Feb 28, 2011 | 06:16 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I ran into the same issue. My builder inspected the factory balancer and we decided to use it. Was in near perfect condition. We initially planned on using a Professional Products balancer, but we made the assumption we could get one for a Vette. All we found were for Fbody and other models; no corvette damper. Just clean yours up and check it closely for any cracking of the rubber. If you are not boosting with a supercharger it should be good for your application.
Old Feb 28, 2011 | 06:32 PM
C4fan's Avatar
C4fan
St. Jude '10
My assessment of the original was more of a "well used" part. The guy who built my short block also said I could stay with OEM. But, with it's assumed age I figured it's better to replace it than risk having it break under the increased hp and possible rpm range. I don't mind spending the $ to replace it but I don't think I need to go all out race parts.
The Pioneer parts are within my range to spend but I've read a couple of threads on here that suggest there have been problems with them. However, that can come from people passing on information that they simply read about. One person posts a complaint which leads to comments on other threads and so on. This very post is an example of that.
Old Feb 28, 2011 | 07:43 PM
93VettePilot's Avatar
93VettePilot
I used the ATI damper but wished that I had stayed stock. The ATI was a pain in the butt to install and if it ever needs to be removed I hope I don't have to lift the motor.
The two piece stock design makes it alot easier to remove and replace.
Old Feb 28, 2011 | 08:40 PM
C4fan's Avatar
C4fan
St. Jude '10
Yeah definitely not going ATI. But still wanted to go better than stock.
Old Mar 2, 2011 | 08:40 PM
1989TTATony's Avatar
1989TTATony
I also used the stock balancer in my stroker build and had the machine shop broach cut it
Old Mar 2, 2011 | 09:22 PM
C4fan's Avatar
C4fan
St. Jude '10
Just ordered a Dorman from RockAuto. The notch is a good idea, how much did they charge to do it?
Old Mar 4, 2011 | 06:17 PM
1989TTATony
? My buddy cut mine at his machine shop I think that Golen does them for $75
To LT1 harmonic balancers
