90-94 dash help please!?
Old Apr 13, 2002 | 06:45 PM
soundkillr's Avatar
soundkillr
Default 90-94 dash help please!?
Hey can anyone tell me how to get the instrument cluster out of a 91 Vette? I think the dashes from 90-94 were all the same. I pulled the lense cover off, and the 4 bolts that hold the cluster in but I cant get it past the dash top, or the steering wheel column. Please let me know how to get this thing out. Thanks
Old Apr 13, 2002 | 10:11 PM
bdtenore's Avatar
bdtenore
Default Re: 90-94 dash help please!? (soundkillr)
Just took mine out last week in my 90. First, you did not need to take your lens cover off. Next you need to take the plactic interior panel that is below the steering column off. Remove the four bolts holding in the knee bolster ( metal ) right below the column, remove bolster. Ok now remove the two bolts holding the column in place. When you remove the bolts the colum will be free to move down so the cluster can slide out. Thats it! The cluster is connected by a group of pin connectors, so be careful when removing it. Can I ask what kind of problem you have with your cluster?
