Automatic Shift Control Harness need HELP
Old Mar 2, 2011 | 05:49 PM
ken46's Avatar
ken46
Default Automatic Shift Control Harness need HELP
So I am trying to install a Automatic Shift Control Harness on my 92 Corvette. I purchased the harness from Mid America and the instructions they give you are crap. I need help from anyone on this forum that has done this mod or that has pictures of how to do it. The harness that I pulled off the trans is different then the plug that is on the new harness from Mid America. I am going nuts trying to figure this out
Someone please help.
Old Mar 2, 2011 | 06:10 PM
rodj's Avatar
rodj
What is it supposed to do?
Got a link?
92 has a NON electronic trans so you can't control anything electronically
Only thing " electronic" in the 4l60 trans is the torque convertor lockup; just a simple OFF/ON wire
Old Mar 2, 2011 | 06:13 PM
ken46's Avatar
ken46
http://www.mamotorworks.com/corvette...1-328-726.html
Old Mar 2, 2011 | 06:26 PM
rodj's Avatar
rodj
The harness that I pulled off the trans is different than the plug that is on the new harness.
how is it different ; plug style or number of wires ?
So it is not a " Shift Control " ; just a manually operated switch to turn off the convertor lockup.
Could do same with <$5 worth of parts from Radio shack
Their documention is wrong anyway
"a fluid activated switch controls the torque converter lockup"
Convertor lockup is controlled by the TCC settings programmed in the computer
Old Mar 2, 2011 | 06:40 PM
3D87C4's Avatar
3D87C4
"Tech Note: Legal in California only for racing vehicles which may never be operated on a highway."
Funny how comments of that sort keep showing up.
Old Mar 2, 2011 | 07:34 PM
rodj's Avatar
rodj
Because convertor lockup is for fuel economy and emissions purposes and you aren't supposed to disable those in CA
Old Mar 2, 2011 | 08:07 PM
383vett's Avatar
383vett
My converter is locked to gain one and a half tenths in the quarter.
Old Mar 2, 2011 | 11:59 PM
ken46's Avatar
ken46
I got it done what a b__ch
Old Mar 28, 2011 | 10:48 AM
C4vettrn's Avatar
C4vettrn
Just curious how a locked converter would help E.T. in the quarter? Are you running some Tall gears? I would think the opposite would be true unless a change in factory gearing? Please educate me. Are you using a toggle switch to turn it on? Thanks!
To Automatic Shift Control Harness need HELP
