need harmonic balancer
My harmonic balancer has some knicks and cracks.
Will this one work ??
http://www.oreillyauto.com/site/c/de...2316&ppt=C0332
No.
The replacement harmonic balancer on your LT-1 or LT4 Vette engine
is usually dynamically balanced with the crankshaft, flexplate-flywheel and predetermined bob weights attached to the crankshaft throws.
A classic Sterwart Warner crankshaft balance machine is used- stoboscopic equipped.
From the operators experience and readings he sees, he knows exact amounts to add or remove in grams for correct balance.
In your case I believe your engine is fully assembled right now.
The balancer shown in the photo you provided has lightning style hole drilled around the front face of it in a circular pattern.
Those holes are to install a solid roll pin for engine balance purposes.
When you remove your old harmonic balancer, you will see a solid pin in one of those lightning holes. It may be covered up in paint, dirt, grease, ect.
Poke around and through with a small screwdriver if unsure.
You should run across the solid roll pin pressed in.
When you find the pin, knock it out with a appropriate sized punch and a hammer.
Be sure to Note where it came from. Exact orientation.
Transfer it to the new balancer in the same location as the old balancer.
I may be entirely wrong, but I believe all factory GM LT-1 and LT4 engines had the balancer as shown in your photo.
If no balnce pin is present.
Don't worry about my directions earlier.
Just install the replacement balancer as shown in the GM Corvette FSM.
Brian
The only problem I see but was looking around and it might not be a big problem.... If you lay the old balancer flat on a table and the new one the same, the old one is about half inch taller ( wider)..
I will bolt the new one on, put the belt on and make sure the path is the same.
Thanks guys
Thanks guys
Be sure you have the right balancer you need beforehand.
Drive yourself nuts otherwise.
Been there helping friends at night.
Spare parts pile add ons to their cars and trucks.
Brian
Should I just take it to a shop or what?
I'm not sure how much was changed in your engine rebuild. But, if the stock components were reused and not internally balanced, you might have an issue if you didn't match balance flywheels.
Even with the pin IN the old harmonic balancer, the new one won't need one put in? I am hoping to just throw the new one on but if I need to have it matched I will.
http://www.rockauto.com/catalog/moreinfo.php?pk=390117
