Also, is there any drone with the chambered muffler eliminators? Exhaust system drone on the road takes all the enjoyment out of a great sounding exhaust system. Our last C5 had a high-dollar aftermarket system on it when we got the car and after listening to annoying exhaust system drone for 750 miles on a trip, I traded the it for a stock titanium Z06 system and lived happily ever after!
I like them a lot,I also went with a rear y-pipe that has the crossover tube and have no resonance at all.Honestly it is quiet inside.Laud out side quiet inside.I also gutted my cat(it was the original one and busted apart in two minutes).You will have better luck ordering off there ebay site.I got mine in a bout 4 days.Others who have ordered direct took much longer,guess they dont want a bad ebay rating so you will get it sooner going that rout.The tone is smooth and deep,not as laud as you would think at idle.Cruising has a good deep tone and at wot it screams!.Heres what the y-pipe w/ crossover looks like.
I purchased the y-pipe through Summit Racing everything fit together nicely.Dont forget to get new gaskets from the y-pipe to cat(you will need 2 if you plan on pulling the cat off to gut it).....I used some hi temp rtv on each side of the gasket.I let the gasket tack up good on the cat itself before putting it all back together.Even on ramps theres not much room under the middle of the car,so having it sticking to the cat helps.
I am running the chambered true dual setup from Allen's. I have no drone at cruising speeds, and is very quiet inside. Sounds really good at idle and really good when you get on it or wot. I like mine...
