1985 w/z51
Old Mar 7, 2011 | 10:44 AM
j/t's Avatar
j/t
Default 1985 w/z51
just want to replace the shocks. this is a 1985 with the z51 package. I guess the obvious first choice would be the bilstein shock absorber,but if by useing another brand of shocks,(ac delco,kyb,ect) I might accomplish just a little smoother ride thats what I am after. its not really a matter of the cost of one brand versa another brand. The car has been in my family since new still has the original bilsteins on it. 42000 miles on the car
Old Mar 7, 2011 | 10:59 AM
ggrassmid's Avatar
ggrassmid
I'm gonna be an @$$ but dont drive a sports car if you want soft.
But changing to the standard bilstiens would be good, I've heard KYB's are softer, but some have had marginal longevity out of them.
If your around the Cincinnati area I'd take you for a ride in my 85 that I will now call a Z51 Plus. I have replaced both spring from standard to Z51, I have the Bilstien autcross shocks, and the biggest solid sway bars made for our cars. Handles exceptionaly better, but can ride a bit rough, but I dont mind, its what I wanted/expected. The worst ride I get with my car is on the new concrete highways in Chicago. There is a slight wave to the concrete and my car holds those waves, I almost have to stop at every rest oasis to ****, as using the cinch button to hold me down otherwise i bounce my head of the targa top.
best way to find out want you like... go to local Corvette Clubs, ask those guys what they recommend, see what they have on their cars. Get a ride in a Standard and Z51 with Bilstiens. Those cars will need to have the suspension that is in good working order.
Old Mar 7, 2011 | 11:15 AM
pmihaltian's Avatar
pmihaltian
Slingshot
You can get Z51 Bilsteins or standard suspension Bilsteins. If your Z51 shocks are a little too stiff, try the standard Bilsteins. This way you will keep the car pretty much stock and still get a slightly softer ride
Old Mar 7, 2011 | 11:16 AM
j/t's Avatar
j/t
don't get me wrong , ain't trying to make a cadillac out of my sweet old vette, but at 26 years old the original transverse springs ain't what they use to be and I ain't any younger either. it still rides very nice on the highway but its a little harsh at low speed
Old Mar 7, 2011 | 11:27 AM
j/t's Avatar
j/t
pmihaltion.......I like your suggestion I appreciate your responce..... J/T
Old Mar 7, 2011 | 11:29 AM
ggrassmid's Avatar
ggrassmid
I dont know how the Monroe shocks you have on the car compare to Standard Bilstiens, but the Monroes probably aren't any good any more, so new shocks might make a difference.
I'm 27yr-old and my car rides a bit rough for my dad at age 55, but for short trips he didnt have any issues. He bought a Z51 86 car that has good suspension and he likes how it rides. I havent heard him complain about it being too rough.
Old Mar 7, 2011 | 01:13 PM
c4cruiser's Avatar
c4cruiser
The C4 fiberglass springs don't grow weak anywhere near as much as steep springs. do. The C4 springs can delaminate but that usually results in failure of the spring.
The Z51-specific Bilsteins are matched to the springs so those shocks will restore the ride to stock Z51 feel. There is a Bilstein "Sport" shock which is a bit softer. Of course road conditions have a lot to do with ride quality; poor road s= poor ride and more work to control the car.
I used KYB Gas-A-Just shocks on my old '78 with the FE7 Gymkhana suspension and they felt stiffer than the factory shock. That suspension was similar to the C4 Z51 in terms of a performance suspension compared to stock, but those KYB shock did smooth out the ride but it may have been simply old shocks vs. new.
Old Mar 7, 2011 | 01:24 PM
383vett's Avatar
383vett
Where did Monroes come from? Did you read the original post? Why would the op want to ride in your car that is setup stiffer than the sport suspension which he is trying to get away from? Are you smoking?
Old Mar 7, 2011 | 01:56 PM
ggrassmid's Avatar
ggrassmid
He posted this: http://forums.corvetteforum.com/c4-g...log-wagon.html in the General Section. Then posted two similar threads in the Tech Section. So technically he does not have a Z51 any more. As there are Monroe shocks on his car and not Bilstiens.
And a ride in my car with all new suspension may show the difference in the old shocks that arent doing anything for him in new shocks, weather stiffer or not. The shocks on my car were shot prior to the change and the "harshness" of the ride is different. It doesnt feel like it slams around like it used to with shocks that were worn out.
Old Mar 7, 2011 | 04:05 PM
383vett's Avatar
383vett
I'm not good at reading between the lines.
Old Mar 8, 2011 | 02:13 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Another Option is to send Your Bilstiens in for a Rebuild. They are one of the better brands to own because of this. Most are throw aways Bilstiens are not.
Old Mar 8, 2011 | 04:42 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I did this
. Spent shipping $$$ to send them to California for rebuild. The got them, told me they could not be rebuilt and then charged me $450+ shipping for replacement shocks. I would have been better off buying replacement Bilsteins from Ecklers or MAD.
Old Mar 9, 2011 | 12:10 AM
Gale Banks 80'
Originally Posted by pmihaltian
I did this
I have a Set of Bilsteins for my C3 that were prepared by John Greenwood just for C3's. They didn't even look like the ones that were the standard ones. I sent them in and it took a wile to get them back because they had to replace a bent Rod and it was a size they didn't have. My only complaint was they didn't Paint them. I know some of the GS guys have had good luck with there 96's.
Old Mar 9, 2011 | 03:13 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Don't get me wrong, I think they are great shocks and I continue to run them. I just did not have a particularily good experience with their rebuild service.
To 1985 w/z51
