WinALDL & TunerPro ????
Old Mar 8, 2011 | 04:46 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Default WinALDL & TunerPro ????
Will WinALDL & TunerPro work on a stock 1985 TPI Vette ???? Will the 1986 chip #16198259, which is the GM replacement for the original 1985 TPI chip#1227165, work in a stock 1985 TPI ECM ??
Old Mar 8, 2011 | 05:11 PM
rodj's Avatar
rodj
Those are ECM numbers; not memcal numbers.
Memcals (chips) are identified by a 3 or 4 letter code on the memcal itself ; ANHY .ARAP ,etc
#16198259 is the later version of the 1227165 which is the '86 - '89 MAF ECM .
Can supply diagnostic data at 8192 BAUD
Completely different from the #1226870 ECM used one year only in '85 (only 160 BAUD )
TunerPro is showing files for use with the '85 ($1F) although I believe WinALDL is program of choice for '85 owners
A '85 can be re pinned to use the later '165 ECM with the better support and tuning capabilities
See
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Possibly cheaper in the long run because you don't need the rare , expensive ,'85 only MAF burnoff module under the dash ; just some $12 relays
Old Mar 9, 2011 | 09:56 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Thank you, Rod. This is just the information I was looking for.
Old Mar 30, 2011 | 06:29 PM
rons85's Avatar
rons85
All true. However - the expensive (but not hard to find - try NAPA) MAF module for an '85 is about as reliable as the Frame. It Never dies, unlike the two relay setup used on following years.
Also - the "bare" PROM chip in the '6870 ECU is dirt simple to read and write - no adapters necessary. Not to mention Cheap. Obsolete chip, but available.
WinAldl, TunerPro, TunerCat - all work fine with the '6870. I personally prefer TunerCat, but in reality TunerPro does the same job. You need the correct mask file for the .bin, either way. They are out there.
Oh - using WinAldl with the 160 Baud '6870 requires lying to the setup routine in the program. It will Work, however.
All of these programs require the right OBD1 adapter cabling - see Moates. They Also are going to require a PC running something Older than Vista or Win7, although I do have TunerCat running under win7 in "virtual PC" (looks like WinXP) mode.
To WinALDL & TunerPro ????
