Have not driven my car much since I have had it but I finally got my interior finished and took it for a long drive and when I got up today I saw trans fluid under the car, most of it is off the passenger side of the trans but the whole pan and t/c cover had fluid on it. Any suggestions on where to start ? I could see clean fluid up on the right side of the trans but the way air blows around under these cars I have no idea where to start. I have cleaned the whole undercarriage so I might be able to tell easier after I drive it again.
Its not leaking when its sitting. It has sat pretty much since I have had it except for a few 15 minute drives. This was after 2 45 minutes interstate drives.
cleaned it up and drove it again. Does not leak sitting running but after I drove it there is so muck fluid and most of it on the passenger side of my car that its impossible to tell right now where it came from. It leaves an overspray on the rear of the car.
I hope its that easy to see. This car has been one problem after another. It has a high rpm vibration as well. when I drive it hard it vibrates before it shifts. Also seems like its on the passenger side of the car. It does not do it under normal conditions just when I run it hard but its very noticable when it does it.
It sounds like its only leaking when under pressure while driving. I'd be checking all the fluid lines carefully where they enter and exit the transmission. Check the dipstick seal, and the seal around the electrical connector that goes into the valve body. Are you sure it's not overfilled? If your lucky PeteK will stumble on this and give you better feedback.
I was actually low the other day. Added a quart and it was ok. It has since pissed out a bunch again. I am going to have to clean it all again as I drove it too much this weekend and its covered again.
Learned a little more about it. Drove it and kept it in 1st gear and it vibrated because of the torque, not the rpm so I need to check the u joints. How do you check the c-beam ? Any tips would be appreciated.
I also have a C72 and H72 codes. I have to play with my shifter to get park and reverse, could the cable being out of adjustment cause these codes and I cannot erase them either ?
Thanks again for everyones help, I learn more about this car every day.
