c4 vette b pillar ground
Old Mar 14, 2011 | 10:06 AM
daronso1's Avatar
daronso1
2nd Gear
Default c4 vette b pillar ground
Please refer to this website.
http://corvetteactioncenter.com/tech...abs_page2.html
I have a 92 vette coupe and the abs chassis ground is located under the trim on the left B-pillar.
I removed 3 screws for the b pillar trim and removed the trim. It looks like a lot of things need to be removed to get to the b pillar ground, since i couldn't see a ground by just removing the b pillar trim.
does anyone have a step by step instructions, what needs to be removed to get to the b pillar ground?
Thank you!
Old Mar 15, 2011 | 12:21 PM
daronso1's Avatar
daronso1
2nd Gear
I found the abs chassis ground.
1) I had to remove the trim on the left B-pillar.
2) I had to remove the black plastic piece
3) once you look up into the b-pillar, you can get to the ground.
Thanks for your help!
