The Red Line bottle is labeled "MTL" and it stands for Manual Transmission-Manual Transaxle Lubricant. Also, it's not an addative, it's synthetic oil used to replace whatever is currently in your ZF 6-speed. :yesnod:
BMW P/N 07510009420 (10w-60) oil.
Approximate oil capacity of the ZF S6-40 is 2.2 qts.
FYI - the BMW 10w-60 oil is fully-synthetic and is used in the BMW M5 engine.
Buy 3 bottles (quarts) of whatever you plan to use.
From: And on the fifth day, subpoenas were served to Obama senior staff
Re: ZF trans recommended lube (YellowC4)
Just put in new clutch, pressure plate, dual mass, throwout bearing, pinion bearing and rear engine seal. Flushed the ZF with Gm 1052931 transaxle lube. My lordy is it running sweet! This must be what they fell like new, I never knew. :D
