electric water pump question
Mar 16, 2011 | 01:10 PM
OK my manual water pump went out replaced it.Now i have bought an electric water pump can i use my old housing (the one that went out) for the electric water pump so that i don't have to tear up my good manual pump. If so any tips anything i should look for? Thanks Chris
Mar 16, 2011 | 01:25 PM
Mar 16, 2011 | 06:56 PM
Quote:
Originally Posted by
jimmymack
I followed this to the letter.
Should be no reason you can't use your old one as a donor.
Good luck. Love mine.
Mar 17, 2011 | 11:26 AM
Definitely use your old one as the donor! I have had the Meziere electric pump in the stock pump housing for almost 10 years now. I did have to have the electric one rebuilt about 4 years ago.
Mar 17, 2011 | 11:47 AM
any ideal what size plug to buy for the timing cover?
Mar 17, 2011 | 04:49 PM
I think when I bought the electric pump, it came with the right size plug. Did yours not come with one? It's been too long for me...
Mar 17, 2011 | 05:32 PM
The Meziere pump comes with a plug for the water pump housing, not the timing cover.
Apr 18, 2011 | 05:11 PM
water pump gear
Is it absolutely essential to pull the timing cover and remove the water pump gear?
Apr 18, 2011 | 05:31 PM
You can leave the water pump drive in place, some do. But, eventually you will more than likely develope an oil leak.
