shocks
Old Mar 18, 2011 | 08:43 PM
joevette94's Avatar
joevette94
4th Gear
Default shocks
hello all does anyone know if the suspension light on a 94 vet can be shut off by installing resister's from radio shack in the wire harness going to shock actuator.i saw many did it on c5 but i don't know if it works on c4's.the suspension light is on and i want it off,of coarse cost is an issue because to replace the shocks the right way is about 800 bucks.the car ride's great only has 85k.shocks feel good but just want light off
Old Mar 18, 2011 | 09:06 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Pull the light bulb
Old Mar 18, 2011 | 09:43 PM
96 lt-4's Avatar
96 lt-4
Tried it on mine after seeing the write up at grandsport registry.Did'nt work.Put bilstein shocks on mine and pulled the bulb(along with the active handling one as well).
Old Mar 18, 2011 | 11:51 PM
joevette94's Avatar
joevette94
4th Gear
Default bulb
how difficult is pulling the bulb,does the entire cluster have to come out.
To shocks
