Oil Pan Recommendation
Old May 11, 2011 | 04:14 PM
1991Z07's Avatar
1991Z07
Originally Posted by Kubs
I looked up Armando and it looks like they only do Ford engines...
In the thread he listed, he did say they did a custom application for him...
Old May 11, 2011 | 05:34 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Mick and Chuck, Thanks very much for your replies. Looks great powdercoated, Mick. I see if the powdercoater can match the Chevy orange I intend to paint the block. What about the dipstick? Can the OEM tube and dipstick be used and if so I assume I'll need to remark the dipstick?
Old May 11, 2011 | 06:46 PM
96GS#007's Avatar
96GS#007
The OEM tube and dipstick can be used. Just note that "full" will now be halfway between the "add" line and what used to be the "full" line. This is because the windage tray sits lower in the Canton pan.
Old May 11, 2011 | 10:11 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Excellent info. Many thanks, Jim.
Old May 11, 2011 | 10:21 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I have done some powdercoating for a guy in Chevy orange, it looks great. I believe he got it at Eastwood's.
Old May 11, 2011 | 10:29 PM
LD85's Avatar
LD85
I've bought two Champ Pans and could not be happier
www.champpans.com
Old May 11, 2011 | 10:59 PM
5abivt's Avatar
5abivt
On my LTX I used a Canton for the previous build. The fit wasn't the best. I had to take the pan off and flip it over and flatten the rails out. I also had oil leaks at several welds and i had to remove the pan ad have the insides welded to try and stop it. Perhaps its the synthetic oil finding its way out but it was pretty bad.
On my new build I use a Jeff johnston Billet fab pan. Puts the Canton to shame. In EVERY way but in the end the Canton can do the job too.
Old May 12, 2011 | 05:57 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
www.champpans.com
Thanks Larry. I did look at CHAMP, but the initial responses I got were that the Canton fit and I wanted to get this ordered so went with the Canton. I guess we'll see how it goes. Hope you're doing well.
Old May 12, 2011 | 06:01 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Good info, Chuck. I may have to buy the powder as this guy probably won't have actual Chevy orange, and I'd like it to match the block as close as possible, so it's nice to know Eastwoods has it. I like Eastwoods as they're happy to ship to APOs. Hope the POR Engine Enamel Chevy orange will be a match for the Eastwood Chevy orange powder.
Old May 12, 2011 | 08:07 AM
Midnight 85
Why not just do the pan with POR-15? That way you know it will match and that stuff is probably as durable as powder. I knew a guy who used the gloss black POR and he did it without gloves,,,,,,, he wore it for 2 weeks.
Old May 12, 2011 | 08:13 AM
LD85's Avatar
LD85
Gotcha, I went with the 7qt stock type pan, I did not want the Road Race style,
Old May 12, 2011 | 01:45 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
I've been kicking that idea around, Chuck. I did my stock block with POR-15 and then their black engine enamel over that and was amazed at how tough it was. Normally after painting you need to be careful with carb cleaner, but I got a bit on this and saw no discoloration or paint coming off when I went to wipe it up. I then tried spraying half a can of carb cleaner on it and it didn't even soften. Not surprised your friend wore it for 2 weeks! I may just POR it then.
Old May 12, 2011 | 02:00 PM
  #33
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
They're definitely nice pans, Larry. If this Canton doesn't clear the convertible braces, I'll be ordering the Champ CP50LTRB.
