92 LT1 SES Light with Code 43... Help!!!
Old Jul 21, 2013 | 05:24 PM
STL94LT1's Avatar
STL94LT1
F-body LT1's only had one knock sensor, maybe this is what he is using?
Old Jul 21, 2013 | 05:53 PM
toptechx6's Avatar
toptechx6
Thanks for the clarification He may be able to make it work then but I think he still needs an early LT1 knock sensor.
Old Jul 21, 2013 | 06:03 PM
LT1 Jeep's Avatar
LT1 Jeep
This is the first time it's ever thrown a code and I have had te same set up sense 1997. My one knock sensor is on the passenger side, and the only thing from a 1988 I use is the 1 wire o2 sensor it was used on many obd1 cars. I am thinking I need the 1992 knock sensor and not the 1996 knock sensor that I put in? Is there anything else that would be associated with a knock sensor code that I could have over looked?
Old Jul 21, 2013 | 06:56 PM
STL94LT1's Avatar
STL94LT1
A 1996 OBDII knock sensor definately won't work with a 1992 OBDI ECM.
Old Jul 21, 2013 | 07:08 PM
LT1 Jeep's Avatar
LT1 Jeep
Using the 1992 knock makes sense, I guess I overlooked that oops. I will pick one up tonight or tomorrow and let ya know if that did the trick. Thanks a ton for the help.
Old Jul 22, 2013 | 03:48 AM
toptechx6's Avatar
toptechx6
Hope that the 92 knock sensor cures the problem. I do have some doubts based on the fact that the old one did not set a code previously. Another possibility is a wiring problem brought on by vibration/chafing due to the misfire or off road operation, that would be the next thing I would check.
Old Jul 22, 2013 | 09:19 AM
LT1 Jeep's Avatar
LT1 Jeep
I did trace/follow the knock wire into the loom and then followed the loom, I didn't see anything but I will check again.
Old Jul 22, 2013 | 09:38 AM
MrWillys's Avatar
MrWillys
Something tells me that if it ran fine for 10+ years it is simply not the 96 vs 92. Hell, how can you even remember what you used back then? Just saying! I would diagnose it as a device, and or circuit failure.
Damn Jeep guys!
Old Jul 22, 2013 | 11:37 PM
LT1 Jeep's Avatar
LT1 Jeep
Well put the 1992 knock in and negative same result the ohm reading on the 1996 vs te 1992 is so close it called with in the acceptable range in thee Haynes book. Visually the wire harnes looks good and is clear of chaffing it's all in a loom that protects it from my stupidity but j am out of options hmmm. When it starts it only takes a few seconds for the light to come on and soon as it does the electric fan comes on too, so I can't help but think those are some how linked together. Sense I have te older style black computer running it with a chip that basically has every thing deleted out of it, does it still have an internal knock sensor module? I know the fined aluminum computers have a knock sensor module inside. I am reaching now sorry if that sounds like a stab in the dark. Thanks again for your feed back
Old Jul 23, 2013 | 03:34 AM
toptechx6's Avatar
toptechx6
The fan comes on by default when many DTC's are set, so you are correct that they are connected. Do you have 5 volt supply voltage at the knock sensor with the key on?
Your early ECM does not have a replaceable knock module.
Old Jul 23, 2013 | 07:39 AM
MrWillys's Avatar
MrWillys
First, the ESC (electronic spark control) unit is on the memcal, and is part of the knock circuitry.
http://chevythunder.com/199295_lt1_t...codes.htm#Code 43
The 9278 ECM is known to be the weak point in these early LT1's. I would consider sending it out to be tested, and or repaired.
Old Jul 23, 2013 | 09:56 PM
LT1 Jeep's Avatar
LT1 Jeep
I checked for the 5v and there was 0v on the connector that goes on the knock. I freaking checked it 5 times to be sure I was touching the contact in the center of the plug, and nothing. I guess I will finish dinner, grab some frosty treats and start opening up the loom to trace out the wire back to the puter. As for the spark control module I replaced it too. This all happened two weeks ago when I was on Petersons Ultimate Adventure 2013. And I always carry most all sensors with me invade something wacky happens like this and I put a new one in as a stab in the dark. But typically don't those either work or they don't?
Old Jul 23, 2013 | 10:49 PM
  #33
LT1 Jeep's Avatar
LT1 Jeep
Ok my bad, my meter had a bad lead on it. I retested the knock plug I am getting 4.85 volts down there. I think that's close enough to 5volts for a jeep right? So now I am thinking about the torque on it? Or put the original gm ignition module back on and test it again.
Old Jul 24, 2013 | 12:58 AM
  #34
LT1 Jeep's Avatar
LT1 Jeep
I am gonna change the plugs tomorrow maybe I have a bad plug do to the previously clogged injectors (I am reaching now) dumping and not dumping fuel in certain cylinders. I removed the knock and installed it lightly to meet the torque spec. Now I know I have the voltage at the knock I am not sure now.
Old Jul 28, 2013 | 07:22 PM
  #35
LT1 Jeep's Avatar
LT1 Jeep
What about this? If I put a plug in the knock sensor hole and leave the knock out but hooked up? Would this give the knock a clean reading?
Old Jul 28, 2013 | 07:39 PM
  #36
MrWillys's Avatar
MrWillys
Yes, but you must ground the sensor.
See here:
Have your ecm tested. You could program the knock sensors out, but if it's short to ground in the ecm it's only a matter of time for other cicuit issues.
Old Jul 30, 2013 | 10:04 AM
  #37
LT1 Jeep's Avatar
LT1 Jeep
Well the spark plugs didn't work but the plugs in the passenger side were a little dirty and smelled of gas. Driver side looked to be about perfect. Does anyone have any other suggestions?
To 92 LT1 SES Light with Code 43... Help!!!
Old Jul 30, 2013 | 10:06 AM
  #38
LT1 Jeep's Avatar
LT1 Jeep
So with the key on and I am getting my voltage to the knock sensor I still may have a short?
Old Jul 30, 2013 | 10:56 AM
  #39
LT1 Jeep's Avatar
LT1 Jeep
I remember someone said the ignition module on the coil is on the same circuit as the knock. Is it possible I put a bad one in out of the box? I thought those either work or they don't.
Old Jul 30, 2013 | 11:07 AM
  #40
MrWillys's Avatar
MrWillys
Have your ecm tested!
