Headlight Bushings
You could probley get them anywhere and cut them yourself.
I feel you could also use ball bearings that are .437 in dia.
Thats how I used to fix FORD power window motors.
http://home.comcast.net/~zrjuan/headlight.html
http://www.corvettefever.com/howto/33098/index.html
3 bucks a set
all it is,is 7/16 dowel cut to .550 long
http://cgi.ebay.com/ebaymotors/CORVE...Q5fAccessories
My gears were fine only bad bushings,You will hear the motors keep running and make a loud clicking noise if the bushing are bad.
I went to the local Ace Hardware and picked up some bushings that had a heavier sidewall. I did have to shorten them slightly to fit into the gear. Ace also had bushings that looked similar to and were the same size as the Home Depot bushing.
The size I have scribbled down was 27/64 by 29/64. Which is length vs. diameter I don't recall.
Total cost for both headlights was under $1.50
Removed the motor and gear assembly and those looked like new.
Put everything back together and tightened all the fasteners, since one was loose. Thinking that since the gears and bushings were OK, that must have been the problem. Turned on the lights same problem.
Installed the new brass gear and bushings (ordered next day air). Same problem.
Got on this forum,and searched and searched and found someone who had the same issue. Thanks Corvette forum It's not the gear, the bushings or the motor.
It's the shaft and the hub that drives the gear being stripped and the motor just spins. The forum member that posted this issue sent his core to a re builder for exchange .
I used a 3/32" drill bit and drilled a hole through the hub (in the one of the dips) and used a small finishing nail as a pin, cutting off the excess length and put everything back together and it works like new.
This was a headscratcher
KC
KC
I am going to try this method too. I went to Home Depot for them today.
There has been another big price increase. You now have to pay $2.01 for 6 bushings (three 2 packs)
To make it easier for people to find them the SKU number has 2 more digits than reported above. The full SKU # is 030699872787. and the part name on the package is "spacer".
I hope this helps.
