E Brake Removal
Old Mar 20, 2011 | 04:03 PM
The Panther's Avatar
The Panther
Default E Brake Removal
I want to permanently remove my emergency brake on my 95. Has anyone done this before? Any issues?
Old Mar 20, 2011 | 06:47 PM
Cyclonite's Avatar
Cyclonite
I took mine out of my '92, so far just removed the handle inside and disconnected the cables on the rear calipers for now... I haven't pulled the cables and all off-yet. But it was no big deal, just a few bolts and pop the cable out of the handle.
Old Mar 21, 2011 | 07:46 PM
jwt1603's Avatar
jwt1603
Pretty easy to do. I had to pull it out to get the Sparco seat to fit.
Old Mar 22, 2011 | 11:55 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Yep, its comming out of my 92. Right now I have the cables leading to the rear calipers zip tied out of the way.
No big deal to remove it all.
Old Mar 22, 2011 | 11:59 AM
383vett's Avatar
383vett
Mine are off. No problems except no e brake.
Old Mar 22, 2011 | 12:32 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I just took my whole assembly off this past weekend. Took maybe 1/2 hour. There are two bolts holding the handle to the frame, then there is a nut right behind it holding the cable in place. Right in front of the driver rear tire there is a cable retainer bolted to the frame that has to come out, and then the cables go through brackets with holes in them, and are held by little retaining tabs on the ends of the cable. I didnt remove the ends on the calipers because the calipers were replaced, but all in all it was an easy task.
Old May 26, 2011 | 12:10 AM
RacePro Engineering's Avatar
RacePro Engineering
Default Bringing up "old business"
So, Gentelemn, did any of you follow through and remove what look to be the difficult parts - the caliper portions of the system?
It would seem to me the real benefit of the exercise, other than clearing a tiny bit more space for seat installation, is to reduce unsprung weight. In that context, a handle, a spring, and a couple of cables, seems quite trivial.
An updates?
Ed LoPresti
Old May 26, 2011 | 09:27 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
On my 92 the rear calipers have been missing the parts to connect the e-brake cable to for about a year IIRC it was a 6MM hex key wrench and 10 min to remove them.
I still haven't got off my duff to remove all the cables and stuff yet.
Old May 26, 2011 | 09:50 AM
Aardwolf's Avatar
Aardwolf
That has all been removed on mine. There is a small hole in the body to fill by the parking brake lever. I cut the hook parts off the calipers too, where the spring attached.
Old May 26, 2011 | 11:50 AM
RacePro Engineering
Thanks James and Andrew,
It certainly did not look like rocket science, but somehow this task has never managed higher than about #79 of our To-Do list. Now that you have reassured me that it is almost as simple as it looks, maybe it will move up in priority.
Regards,
Ed
Old May 26, 2011 | 10:10 PM
93Rubie's Avatar
93Rubie
Why, would you do this, I could understand in a race but in a street car?
Also, you must not live in a area that has a state inspection. I would fail a car with a non-properly working e-brake much less not having one at all, every time.
FYI, your hydraulic brakes fail and you have no back up. Your pretty much screwed.
Old May 26, 2011 | 10:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
Read my mind
Old May 26, 2011 | 10:45 PM
RacePro Engineering
Not to be mean, but who said anything about street car?
Originally Posted by RacePro Engineering
. . . . . It would seem to me the real benefit of the exercise, other than clearing a tiny bit more space for seat installation, is to reduce unsprung weight.
I will whole-heartedly agree that if our brakes go out, it will not be pretty! But using a device that would lock-up the rears would only add to the damage.
Ed
Old May 26, 2011 | 11:12 PM
cv67's Avatar
cv67
St. Jude Donor '05
That weight of the ebrake assy wont slow you down come on guys
Old May 27, 2011 | 09:26 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Yea, but one of my reman calipers didn't come with the e-brake hardware on it. The handle assembly is in the way of a wide enough race seat. Big brakes don't come with parking brake provisions.
Any one want to add to the list?
It is a couple pounds though.
Old May 27, 2011 | 10:53 AM
Aardwolf's Avatar
Aardwolf
Weight removal is difficult for people with no experience to understand. Having the attitude that a little can add up will take you a long way. There is a huge difference in my car with its weight loss. Leave out acceleration and just look at braking, less weight is letting my car brake much later than it did at stock weight. Braking later than your competitors is a large advantage.
Old May 27, 2011 | 12:12 PM
jwt1603's Avatar
jwt1603
Every little bit adds up.
To E Brake Removal
Old May 27, 2011 | 01:21 PM
pcolt94's Avatar
pcolt94
I have no opinion whether to leave it on or off.
But it is really a parking brake and to call it an emergency brake is a real joke, at least from my experience.
If I pull my brake at 20 MPH don’t stand in front of me because the rate it slows down is not much better than putting you foot out on the ground. It does not do much and don’t think there is a chance of locking the rear wheels up.
I did once lose the breaking on the left front once due to the loss of a caliber bracket bolt while a way from home. I did use the parking brake as an aid to stop the car as I did not want to step on the brakes hard while things were loose and banging around. But had to give myself lots of room to stop and picked a point way back from the car ahead.
Old May 27, 2011 | 03:01 PM
RacePro Engineering
Yup - the Devil is in the details! I don't know if it's a couple of pounds per rear corner, but for argument sake, let us assume so. For UNsprung weight, there is a generally accepted multiplier of 3. So we are dragging the equivalent of 12 extra pounds around the track - minuscule, right? Well, at a place like The Glen, with 11 turns, that tiny extra weight is hampering us 33 times EACH LAP (for each turn: under braking, during cornering, and while accelerating). Multiply that resistance by a 20-lap race, and - well, it becomes significant.
And yes, on a heavy car like our C4, such details are not as dramatic an improvement as on a lighter, more nimble racer.
Are there other efforts where we can gain performance advantages? Certainly! Are these other efforts essentially "free"? If you know of any, please let us know!
Ed
Old May 27, 2011 | 03:18 PM
aklim's Avatar
aklim
I guess it begs the question "Why?". If it is to reduce unsprung weight for a race car, absolutely. If it isn't for a competitive reason, I'm not sure what you will gain for the effort. Fuel savings, unless you drive a million miles won't work to squat so why bother? If the owner is like many and who are too cheap to fix it right, why not just leave it there? It isn't hurting anything
