I am. That is why I am asking for help. Can you offer any actual help? The "smiley faces" aren't really helpful. is 10,700 lb unreasonable? According to Kubs, the one bearing is rated over 7,000 lbs...
Originally Posted by Kubs
lbf is pound-force not ft-lbs. kN is kilo-newtons and that would be 31.4 kilo-newtons or 31,400 newtons or 7,059 pound-force.
Sometimes commas are used as decimals in that system. I have no idea why.
This is excellent info. I wondered about the comma. I don't know why they do that either. Thank you for the info. Both those bearings should work for my application then. Thank you!
I'm intending to use it on the clutch system of a car. I estimate that it could have to deal with a force of up to 600 lbs, and a max of 2000 RPM. The force would only be incured while the clutch pedal is depressed, and the RPM could/would be any time the engine is running.
What does "10 700 lbf" mean in lay-terms, the load in pounds that the bearing can manage?
It means the bearing can take a thrust load of 10,700 LBS, compared to the other bearings 7059 LBS.
Well that certainly seem logical. Thanks again, for the reply. I don't know what the "bearing king's" deal was when I said that in the first place. Thanks again, bjankuski.
I was going to help you out but with that attitude you are on your own.
