dana 44 ?
Old Mar 23, 2011 | 12:40 AM
2outlaw1993's Avatar
2outlaw1993
Default dana 44 ?
ok i know there are a lot of threads on here for the dana 44 swap but i figured asking would be a whole lot easyer.. so what all do i need to buy to switch my 1993 to a dana 44... im just trying to get a list together...
Old Mar 23, 2011 | 01:28 AM
vetteoz's Avatar
vetteoz
Originally Posted by 2outlaw1993
so what all do i need to buy to switch my 1993 to a dana 44....
A D44 diff with batwing , a D44 driveshaft and a D44 C Beam
Old Mar 23, 2011 | 07:39 AM
C409's Avatar
C409
..... To swap from a Dana 36 to a Dana 44 you need a 44 complete with batwing ... you will need a D44 driveshaft OR you could have yours shortened by one inch and re-balanced by a competent driveshaft shop ... mine cost less than $100 ... and a D44 C-beam OR you could redrill the mounting holes at the transmission end one inch further back toward the diff ... everything else is a bolt in ................
Old Mar 23, 2011 | 08:17 AM
2outlaw1993
wow ok thank you....i thought i had to switch out the calibers and all but i guess not...can you just by a d44 driveshaft and will it work without problems?
Old Mar 23, 2011 | 07:17 PM
rodj's Avatar
rodj
All C4's use the same outer susp components and brakes ( year for year ) regardless whether a D36 or a D44 was fitted
Old Mar 24, 2011 | 03:33 PM
2outlaw1993
ok cool thanks for the info
Old Mar 24, 2011 | 03:57 PM
Calderone's Avatar
Calderone
Im putting a list of "while you are there" together .-
For example i would upgrade some suspension components as well...or so
Soon i picture myself doing this D44 Swap ...
Old Mar 24, 2011 | 04:00 PM
Calderone's Avatar
Calderone
if im not wrong there was something about the yokes ..
some are re-usable and some not ..i cannot remember ..
Old Mar 24, 2011 | 06:52 PM
vetteoz's Avatar
vetteoz
Nope
You use the inner yoke that comes with the diff ; both use 1350 series uni joints
The outer yoke doesn't change
To dana 44 ?
