Track Car Cam
Old Mar 24, 2011 | 01:07 PM
BevoVette's Avatar
BevoVette
Go with the COMP Cams CCA-17002-16 Aluminum non-self aligning rockers for $160.95 from Summit.
http://www.summitracing.com/parts/CCA-17002-16/
These are 1.6:1...a great bargain in aluminum. Use the rocommended COMP plates if you are using an existing head.
But consider the Patriot Freedom Series 190cc aluminum heads for $895 per set...they flow 210 @ 5000 rpm intake and about 192 @ 6000 rpm ex...a real bargain...CNC port matched to a Fel Pro 1206 intake gasket.
Old Mar 24, 2011 | 01:50 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by BevoVette
Go with the COMP Cams CCA-17002-16 But consider the Patriot Freedom Series 190cc aluminum heads for $895 per set...they flow 210 @ 5000 rpm intake and about 192 @ 6000 rpm ex...a real bargain...CNC port matched to a Fel Pro 1206 intake gasket.
Doesn't sound like an LT1 head.
