Looking for a cam for my 95 LT1 which is used only at the track(road Atlanta, Cmp, roebling). I will be doing headers and roller rockers too. Everything else on the motor will be stock. I would sacrifice some power for reliability. Any recommendations?
After a bunch of reading I like the cc503 with 26918 beehive springs. I know which locks, rods and retainers to get, but the rockers they recommend are 1.52. Are these correct for this setup?
You are definately going to want to maximize your redline. I think you can go to about 6500 RPM with stock style lifters.
The hotcam is waaaay too mild. I'd go with a high lift, .575 or so (with 1.6RR). If you don't mind losing a little driveability you could even go higher. But you'll need snappier springs to get them closed quickly enough.
And with stronger springs comes better pushrods, and lifters. Im not sure at what point the stock lifters start to compress but if you go too stiff on the springs it can actually collapse a hydraulic lifter. Not good.
With stock heads I dont really see a need to go higher than .575, ported heads yes higher would work better. I think the cc503 with 1.6 rockers and a GOOD exhaust (longtubes with dual pipes out back) would get you where you are looking to go without going to a custom grind.
Which roller rockers? I am thinking non self aligning, but having trouble locating what will fit and the plates to go with it.
I am not sure which rockers clear OEM valve covers, but any 1.6 that fit a 3/8" stud will work. If you go non self-aligning you can use these guideplates: http://www.summitracing.com/parts/CCA-4808-8/
