I did a stupid thing this weekend,As i do every spring and mid summer,I clean my in take,Well i was cleaning my mass air flow sensor and after i sprayed some carb cleaner through it,I was wiping it out,And the other half came out and said she was going to the store and then started talking to me,And i must of stop paying attention and as i was wiping i broke off the wires inside of it.And i did not know it until i put it back together and the check engine was on and when i gave it gas it backfired.So i know i gotta order a knew one,But is there any way it could be bypass to drive it or is it done until i get the new one
To get distracted she must have been wearing something tight?
If the MAF were to be unplugged wouldn't it go into limp mode and be drivable?
I was looking online to buy a new mass air flow sensor,Would it make a difference in which brand i buy,They all claim it does not matter,But i would like other opinions,They have the Python,Ac delco,Cardone industries and Bosch.
You have to keep it stock or the value will go down.
its been my understanding that the 86+ models will work on the 85, but the 85 model will not work on 86+. i could be wrong, but thats the wisdom i gathered when i was shopping for a new one for my old 85. i ended up ordering a new one from mid america, worked good for the time i had it.
Take a look at this thread. You may wanna consider this as I think the MAF is pretty expensive. More work but better gains. I will probly do this if mine fails.
You still need a MAF. I did the swap and am using the original MAF. 85 and 86-89 are different, no clue as to the differences. Summitt says the Granatelli will fit all years. Seems like a better solution than the insane cost of a new Bosch.
