86 rough running.
Old Mar 26, 2011 | 05:30 PM
jdenn47's Avatar
jdenn47
Default 86 rough running.
I have an 86 that is hunting at idle. Running rough between 5 and 7 K RPM at idle. Also runs rough when driving, like it is missing. Fuel pump and injectors tested OK. New MAF, plugs, wires, dist. cap and fuel filter. Was told it could be the TPS or vac leak. Runs a little smoother when disconnected.
Thanks, JD
Old Mar 26, 2011 | 06:05 PM
davenbocafl's Avatar
davenbocafl
86's are nortorious for leaky injectors even though they check good, take your plugs out one at a time and ill bet youll at least figure out what cyl. is giving the problem
Old Mar 26, 2011 | 08:07 PM
tehcarguy's Avatar
tehcarguy
Originally Posted by jdenn47
..Running rough between 5 and 7 K RPM at idle...
I would think these engines would run a bit rough at 7k rpm. I just replaced the injectors in my 86, and it idles very smoothly now, and it feels stronger when accelerating. Call jon at FIC he'll hook you up with some injectors if that's the way you want to go. Also, check timing, check for codes etc..
Old Mar 28, 2011 | 09:28 AM
Sandpiper59's Avatar
Sandpiper59
There are a ton of threads on this board you can search and read through covering rough running but intake air leaks, dirty IAC's, wrong intitial timing, dirty injectors and improper setting on TPS are by far the most common.
You say it runs smoother when disconnected, but you don't say what is disconnected unless you mean the TPS, it should throw a code running that way and have little or no throttle response..
Old Apr 10, 2011 | 11:15 AM
jdenn47's Avatar
jdenn47
Yes, when TPS diconnected, throws a code. Replaced TPS, not as much idle hunting. Now idles between 600 and 700. Checked for vac leaks. Fuel inj. checked out OK. Timing OK and MAF was replaced. Cleaned throttle body too. I will check the IAC.
Old Apr 10, 2011 | 07:06 PM
1986coupe's Avatar
1986coupe
Are all the spark plug wires going to the correct plugs?
Don't laugh, I did that once.
Old May 2, 2011 | 07:17 AM
jdenn47's Avatar
jdenn47
Replaced the IAC and not much of a change. Spark plugs tight.
Can the O2 sensor possibly cause this issue? No codes thrown.
Old May 2, 2011 | 09:45 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
6-700 is not much hunting, even more so if it was hovering between 695 and 705.
You may want to try and set your minimum idle and TPS idle voltage.
http://www.lbfun.com/warehouse/tech_...ch%20Paper.pdf
To 86 rough running.
