new 427 LT-1 engine question
Old Mar 28, 2011 | 02:57 AM
2012 coupe's Avatar
2012 coupe
Default new 427 LT-1 engine question
I just put in a new/rebuilt 427 LT-1, ( or maybe not, as I am finding out) into my 1992 vette. Problem I have is after running it for 300-400 miles, 75mph on freeway, after being stopped/off for about 10 minutes, and then restarted, it blows blue smoke out of both sides of the exhaust pipes. The smoke goes away after about 2-3 minutes of idling. Other wise it runs great, no smoke, runs cool and getting around 19.8mpg. This is the first long trip I have taken it since the new motor was installed. 2,800 miles on motor.
Old Mar 28, 2011 | 03:28 AM
cv67's Avatar
cv67
St. Jude Donor '05
427 out of a 350 lt1?
Could be your valve seals or more. Does it smoke on decel?
Old Mar 28, 2011 | 08:06 AM
bjankuski's Avatar
bjankuski
I agree, sounds like valve stem seals allow oil to drip into chamber when the engine is off.
Old Mar 28, 2011 | 09:25 AM
93VettePilot's Avatar
93VettePilot
I've never heard of a 427 LT1. 396 and 383 but never 427. Is this an aftermarket block or something.
Just curious.
Old Mar 28, 2011 | 10:44 AM
Richard Church's Avatar
Richard Church
Old Mar 28, 2011 | 11:19 AM
STL94LT1's Avatar
STL94LT1
Is today April 1st?
Old Mar 28, 2011 | 01:10 PM
tpi 421 vette's Avatar
tpi 421 vette
Actually, you can make a 427 out of a 350. I wouldn't recommend it though, and I don't know anybody that has tried it. 4.060 X 4.125. A 4.125" stroke is a PITA, and the 4.060" bore would probably make the cylinder walls thin depending on the block. And there would be no rebuilds left in the block afterwards.
There are no aftermarket blocks for a LTX that I know of that you can use a 4.125"+ bore.
Old Mar 28, 2011 | 03:23 PM
2012 coupe's Avatar
2012 coupe
Default Smoke
No smoke on decel and around town use. I am taking it in tomorrow to find out if the engine was built wrong.
Old Mar 28, 2011 | 03:31 PM
2012 coupe's Avatar
2012 coupe
Default Problem
Could be a "383" instead of a 427? Just looked at sales invoice, says, "Corvette LTx" I bought it as a "long block" from a builder in WA, state last October. I am going by what they said. I had it delivered to the shop that installed it, that is another whole story in it self. The more problems I have with it, the more I think I should of just rebuilt the old LT-1 with 286,000 miles on it.
Old Mar 28, 2011 | 04:36 PM
syco_cop's Avatar
syco_cop
It's a smoker cuz it's a stroker.
Old Mar 28, 2011 | 09:29 PM
93VettePilot
You would hit water first. Dart had a prototype LT1 block a few years ago but it was too expensive to mass produce for a very small LT1 crowd.
Old Mar 29, 2011 | 12:02 AM
tpi 421 vette
I have done a 4.125" stroke before... I have one in my car 450ci 4.165X4.125. And you definately will hit water. That is why you must low fill the block. Because you will end up going thru the block doing it. It's not like a 1/2" hole. Maybe 1/16" to 1/8".
Block filler isn't a bad thing. A low fill to the bottom of the freeze plugs will seal the block and make it stronger.
Old Mar 29, 2011 | 12:43 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
You need to find out WHAT they sold you. If you don't know what it is, who knows what is inside it???????
Old Mar 29, 2011 | 02:20 PM
93VettePilot
Ok. Gotcha. Didn't think about filling the block.
Old Mar 29, 2011 | 04:41 PM
2012 coupe's Avatar
2012 coupe
Default Motor
Turned out to be a 383, not 427 as they said. Problem was the EGR valve, fixed now. Thanks for everyone's "heads up", I just bought it, had it shipped to the garage and they installed it. I am now talking to the people who sold it to me about their sales invoice stating it was a 427 Corvette LT-1.
Old Mar 29, 2011 | 11:42 PM
cv67's Avatar
cv67
St. Jude Donor '05
Sounds like you may have a case there in court that sucks.
Keep us posted on teh oil issue.
Old Mar 30, 2011 | 01:13 AM
383vett's Avatar
383vett
Buyer beware. Good luck.
To new 427 LT-1 engine question
Old Mar 30, 2011 | 08:20 AM
Calderone's Avatar
Calderone
wow i would be really pissed off if i get a 383 after buying a 427 !
Old Mar 30, 2011 | 02:03 PM
5abivt's Avatar
5abivt
I don't understand how anyone can buy an engine without knowing what exactly it consists of. A (supposedly) rebuilt engine can be a few hundred $ to $20k or more. Not knowing what you are getting I like writing a blank cheque.
Old Mar 30, 2011 | 02:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
Unless he really knew about engines and it came sealed up it would be hard for him to tell, gotta trust someone.
