1990 Idle Problems
Old Apr 1, 2011 | 01:41 PM
858690Vette's Avatar
858690Vette
Cruising
Default 1990 Idle Problems
I have a 1990 with 98,500 miles. I drive the car once or twice a week. The last two times I have driven the car, I had idling problems. When the car starts cold, the engine idles at 1500-1800 rpms (around 1,100 rpms in gear). The engine will idle fast no matter how long you drive it, unless after it reaches normal temperature you turn off the ignition and restart the engine. Then it idles normal at 650 rpms in gear. It will idle fine until the engine completely cools down. Then it repeats the problem. The battery, alternator, fuel pressure, and fuel injectors check out ok. Any help would be appreciated.
Old Apr 1, 2011 | 02:41 PM
Crowhater's Avatar
Crowhater
Do you have any vacuum leaks? Did this just start out of the blue?
Old Apr 1, 2011 | 03:26 PM
bill mcdonald's Avatar
bill mcdonald
Sounds like clogged IAC port, or the IAC motor is going out.
Old Apr 1, 2011 | 05:47 PM
tehcarguy's Avatar
tehcarguy
Make sure the throttle is back against the stop when it's idling.
Old Apr 2, 2011 | 07:32 PM
858690Vette
Cruising
The idling problem just started immediately. I checked for vaccum leaks and couldn't find any. Also, the throttle is returning against the stop. I will check to see if the IAC port is clogged next and report the outcome. Thanks.
Old Apr 15, 2011 | 03:45 PM
858690Vette
Cruising
I cleaned out the IAC port last week. I have driven the car three times and it is idling correctly. This seems to have fixed the problem. Thanks.
To 1990 Idle Problems
