Problems with coolant sensor/gauges
Old Apr 3, 2011 | 02:56 PM
vettef6's Avatar
vettef6
Default Problems with coolant sensor/gauges
My analog and digital gauge show a high increase in coolant temperatures. The digital shows 220° and my analog gauge is all the way to the stop. Pulling the connector from the passenger side sensor, which is the sensor for the gauges, nothing happens. Pulling the sensor from the water pump, the temperature drops about 25°. Since this is the sensor for the ECM, I'm a little confused.
The manual doesn't help at all, just shows the relationship between volts and ohms.
Maybe it's just the wire leading to the gauge sensor that is frayed or grounded. I will check this tomorrow.
I appreciate any help in this matter.
I forgot to mention, it's a 1992 LT1 and the temperature was actually about 120° but the gauges showed about double.
Old Apr 3, 2011 | 03:23 PM
sailorsteve's Avatar
sailorsteve
What year is your car? The analog gauge is usually less accurate than the digital.
Old Apr 4, 2011 | 06:52 AM
vettef6's Avatar
vettef6
As you can see I edited my post.
Old Apr 4, 2011 | 01:07 PM
OkieC4's Avatar
OkieC4
I remembered a recent thread covering a similiar problem on a 94 LT1 maybe it will help..
http://forums.corvetteforum.com/c4-t...-1994-lt1.html
Also a good writeup on the LT1 cooling system.
http://www.corvetteactioncenter.com/...Cooling+System
Old Apr 4, 2011 | 04:58 PM
vettef6's Avatar
vettef6
No this doesn't help me at all. I'm not concerned about the two gauges showing different temperatures. It's all about them both showing the engine is very hot, but the water is actually cold or lets say about 120°
Old Apr 5, 2011 | 12:17 AM
OkieC4's Avatar
OkieC4
On the analog gauge, I would agree that you have a short to ground on the single wire between the sensor and the IP if with the key on and the eng off it pegs hot.
Being an L98 guy, and from what I have read, 220 is not unheard of with an LT1. IIRC, the fans don't even come on until around 225.
If this happened suddenly, any chance of this being a stuck thermostat? As the LT1 is a reverse flow bypass cooling system, that might explain coolant temps around 120 at the tank...
Old Apr 6, 2011 | 03:59 AM
vettef6's Avatar
vettef6
Al, thanks for trying to help me, hopefully others will chime in and find a solution to my problem.
I haven't been running a thermostat for a couple of years now, so this isn't the problem.
I drove a while yesterday and noticed both gauges show the correct value, starting with the ambient temp. and then going up to 235°. Normal temperature for my setup has been around 180° for many years. You can touch both coolant hoses coming in and out of the radiator. If the temp. would really be that high, I wouldn't be able to grasp the hose and hold it for minutes if need be....
Old Apr 6, 2011 | 08:17 AM
OkieC4's Avatar
OkieC4
I'm sure the LT1 gurus will chime in, but after reading your last post and learning you are not running a stat, I would lean toward a couple of things...
1. Water Pump impeller wear/cavitation - air in the system? - several threads here and on other LT1 forums discuss loss of head pressure for WP ops with no stat.
2. Partially clogged radiator - restricted flow would keep coolant in bypass.
Anyway, I found a good step by step indication troubleshooting procedure over on a F Body LT1 tech site which might help you check the analog and digital wiring.
http://shbox.com/1/4th_gen_tech2.html
It's about 1/2 down the article titled Testing the ECT Sensors and Connections.
Good Luck....
Old Apr 6, 2011 | 04:33 PM
vettef6's Avatar
vettef6
I made a hard copy of the article and will be checking tomorrow.
Arnold
Old Apr 12, 2011 | 07:31 AM
vettef6's Avatar
vettef6
Just wanted to let you know, checked all sensors and connectors, everything is alright. I'll put new ones in just to make sure.
FYI, it's a head gasket. I'll be replacing them in the next few days and everything should be running in a week or so...
To Problems with coolant sensor/gauges
