Hood doesn't "pop" up...
Old Apr 5, 2011 | 09:50 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by pcolt94
I had that problem also. Traced it back to the driver's side latch. I loosed the adjustment on the hood but set it with light friction so it could just move but hold position. Closed the hood and itself centered. Then I locked it down and never had the problem.
You might have to loosen both first just to find out that the latches are the problem.
This wins my vote for most likely problem. If the pins aren't centered within the "receiver" they land in, it can create drag upon reopening. If the drag is sufficient, it could overcome the spring's ability to pop the hood.
Make sure the pins are centered before replacing any parts. (Unless you just want to.)
Old Apr 5, 2011 | 10:48 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Originally Posted by Dave C
I feel your pain Midnight - why would they be the only vendor that has this? What exactly gets upgraded with their kit? Is it something that can be homemade?
Dave C
You can bet I am going to be doing some long hard looking at what else can be done without putting extra stress on the cables.
Old Apr 5, 2011 | 11:03 PM
Midnight 85
Guys, I just got an email from corvette recycling, they sold ALL their upgrade kits to another parts dealer. All I am going to say is why would they do that?? I wouldn't use that kit now if it was free. I am going to see what I can come up with tomorrow, I will post whatever I find.
Old Apr 5, 2011 | 11:53 PM
oldalaskaman's Avatar
oldalaskaman
they were selling the complete kit for $49 the others sell the parts for $49 each, the parts you need are the stronger springs and the pins, both are different and better quality then oem, everything else is just extra, I still have the extra parts in the box they came in cause they werent needed.
Old Apr 6, 2011 | 05:58 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Gregg's right, my input is based on a properly aligned hood and associated components. What I'm talking about is a hood that had tired springs as they all will after a certain amount of time. If you store your car over Winter, release the hood. This relaxes the springs and may extend their life.
The kit I list in my paper was from GM and contained a new cable set, new latches, new release lever and new springs/pins. I used all the parts in the kit just because they were new. The GM part number is 10273994 and it is available from Corvette Central @ $109.95.
Old Apr 6, 2011 | 08:59 AM
Midnight 85
Thanks Ray, that makes me feel better knowing that someone else sells the kit. I'll check that out. It was looking like the kit was only available from one source and then they sold all they had to another company. I had already checked Corvette Central but probably didn't use the right words in the search.
Old Apr 6, 2011 | 10:43 AM
oldalaskaman
Originally Posted by Ray Quayle
Gregg's right, my input is based on a properly aligned hood and associated components. What I'm talking is a hood that had tired springs as they all will after a certain amount of time. If you store your car over Winter, release the hood. This relaxes the springs and may extend their life.
this is excellent.....shame on you corvette recycling, for selling to a dealer.
Old Apr 6, 2011 | 12:16 PM
Midnight 85
Well guys, I was wrong. I claimed earlier that my latches were aligned perfectly and come to find out my passenger side was just a hair off center. I couldn't see it with grease as a marker so I used soapstone to color the tip of the pin. Sure enough, just a trace of white on one side. I adjusted it so all was clear and my hood now pops up at least an inch. I went ahead and replaced the assist too and now not only does the hood pop up but I can lift it halfway with one hand and it will go on from there by itself. So, 383vett, pcolt94, GREGGPENN, and Ray Quayle, you were all right about the alignment being critical, super critical. I'm sure glad I checked it out before spending all that $$$.
I would suggest that anyone with the "pop up" problem to take a little time and fine tune the aligment, it only has to be off about a sixteenth of an inch to hang up.
Old Apr 6, 2011 | 02:44 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Great news, Chuck. Thanks for the update. The soapstone was a great idea for checking alignment.
Old Apr 6, 2011 | 05:52 PM
ffvetteman's Avatar
ffvetteman
Great info. Just saw this thread and I am going to have to align my pins. I have been doing the 2 handed open for 14 years!!!!
Old Apr 6, 2011 | 06:04 PM
Dave C's Avatar
Dave C
ME TOO!
Good idea about relaxing the springs over the winter Ray - but my car is 25 years old but only has 49k miles on it. That being said, the hood has probably been latched for longer stretches than most...
I'm going to try and align my pics next chance I get - thanks everyone!
Dave C
86L 4+3 Coupe
Old Apr 6, 2011 | 06:14 PM
GREGGPENN's Avatar
GREGGPENN
Dealer is another name for retailer. Even Corvette Recycling is a "dealer".
Guess they didn't want to handle that part anymore. Maybe it'll show up on eBay?
Midnight85....Glad you fixed the problem!
Old Jul 4, 2012 | 11:31 AM
  #33
chrisd0729's Avatar
chrisd0729
Double thumbs up on this one- did this and greased the pins and seats ad it works perfect now!
