Hood doesn't "pop" up...
Old Apr 4, 2011 | 09:33 PM
Dave C's Avatar
Dave C
Default Hood doesn't "pop" up...
Hi Guys - Just grabbed my 3rd C4 last week, an 86L 4+3, Black Coupe with 49k miles.
I'm noticing that when I pull the hood release with my right hand, I need to simultaneously pull the hood up with my left hand as it doesn't "pop up" that 1/2" or so to escape the latch - it's almost a two-man operation.
Are my latch springs worn? Are they adjustable?
I also ordered two new front struts to help lift the hood the rest of the way.
Dave C
86 4+3 Coupe
Old Apr 4, 2011 | 10:39 PM
383vett's Avatar
383vett
Nice ride. When you slowly close the hood, do the springs want to keep the hood from closing? Do they keep the hood up a half inch or so. If they do, your springs are ok, the latch needs to be centered. If they don't, your springs are probably shot. Good luck.
Old Apr 4, 2011 | 10:46 PM
Dr.Huxtable's Avatar
Dr.Huxtable
I'm pretty sure you can also adjust that pin that goes in the middle of the spring no? It has a slat on the nose of it. Just assuming!
Old Apr 4, 2011 | 10:54 PM
oldalaskaman's Avatar
oldalaskaman
call corvette recycling, a vender on here and have them send you the 'up graded' spring kit, $49 bucks and the best money you'll spend. Includes everything not just springs
Old Apr 5, 2011 | 05:43 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Dave, This is called the "Corvette Reach Around". I wrote a paper some years back on this very issue. The part numbers are most likely outdated, but I'd be happy to send you a copy in pdf format. It mentions the upgraded springs that oldalaskaman pointed out. This would likely be enough for you, but I updated the hood prop to the later gas charged (I also have a late '86) and also replaced the hood assists at the same time. After that, my hood would pop even with someone sitting on it and I'd only have to lift it a few inches and it would raise the rest of the way on its own.
Old Apr 5, 2011 | 07:35 AM
WW7's Avatar
WW7
Also, you may not have the cables adjusted correctly to retract the lock far enough to release the pin. When you pull up on the hood you may be pulling it out of the locking mechanism which isn't opened all the way...Just a thought.....WW
Old Apr 5, 2011 | 07:43 AM
leesvet's Avatar
leesvet
Spring upgrade and adjustment of the long pins on the hood. Loosen those at the flat nut, not the cone. Once those are stretched out then look at the body stop pads. `The ideal adjustment will have some tension on the rubber pads but not binding. This allows the hood to "pop" when the latch is released. Be careful when doing this....its easy to get it too tight and stuck..
Old Apr 5, 2011 | 08:25 AM
oldalaskaman
i spent over a month adjusting, streaching , a just generally getting agravated with the oem hood springs, bought the 'complete upgrade kit' from corvette recycling, threw away the 'emergency' cable releases, they work that good.
Old Apr 5, 2011 | 08:51 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Care to share a link or part number? I looked all through their website & came up with nothing.
Old Apr 5, 2011 | 09:28 AM
oldalaskaman
I just looked also, and didnt find it , you might call them on the phone , they were advertizing it and it may not have made they're new list.
Old Apr 5, 2011 | 10:26 AM
383vett's Avatar
383vett
That's pretty cool. I've got to do a 60 lb bench press every time I open my hood.
Old Apr 5, 2011 | 11:46 AM
pcolt94's Avatar
pcolt94
I had that problem also. Traced it back to the driver's side latch. I loosed the adjustment on the hood but set it with light friction so it could just move but hold position. Closed the hood and itself centered. Then I locked it down and never had the problem.
You might have to loosen both first just to find out that the latches are the problem.
Old Apr 5, 2011 | 12:47 PM
MyFirst90coupe's Avatar
MyFirst90coupe
Are they supposed to work like that? That would be sweet.
Old Apr 5, 2011 | 02:26 PM
in-vette-uation's Avatar
in-vette-uation
Nice car! I assume you've already given it the lube treatment. I had this problem and it was as simple as spraying some lithium grease on the latches and my hood pops every time now.
Might as well try it, it's nearly free.
Old Apr 5, 2011 | 05:51 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
I hear ya Willie!
Not exactly. The early cars had a hood prop that had no assist. In actual fact the very early C4s had scissor type props, but I'm not talking about these. The non assisted props used two hood assist cylinders at the base of the hood. When they went to the assist type prop they used only one assist cylinder at the base of the hood. If you look closely at your '90 down at the base, you'll see one small assist cylinder, but the mounts for the second are there on the other side. When I did my upgrade I replaced both the assist cylinders with new ones and added the assist prop. This makes the hood sort of shoot up the last foot or so, probably why the factory removed one of the assist cylinders when they went to the assist prop on the later C4s.
Old Apr 5, 2011 | 07:31 PM
MyFirst90coupe
I have to lift mine all the way. And if I don't make sure that the "safety" is on, it will slam if a wind blows or if I jack it up...ask me how I know
Old Apr 5, 2011 | 08:19 PM
Dave C's Avatar
Dave C
Thanks Ray and everyone else, I appreciate of the input. My last 86 was the same way, but the hood "popped". I then added two new assist struts at the base of the hood, but never got to the gas-prop rod upgrade - I'll do it for sure on this car, the older I get the heavier these damn hoods are!
Drive safe,
Dave C
86 Coupe 4+3 black 49k miles
To Hood doesn't "pop" up...
Old Apr 5, 2011 | 08:47 PM
Midnight 85
Corvette Recycling is out of the upgrade kits, I put in a request for them to email me when they get some in. I know mine is aligned perfectly, last year the hood did raise maybe a 16th of an inch, just enough you could see it move. This year the latch has slipped back into place a few times after I pull it so it's obvious the springs are gone.
Old Apr 5, 2011 | 09:12 PM
Midnight 85
I have spent the last 2 hours going through every Vette parts dealer I could find. No one, not one dealer had this kit. That makes me a bit doubtful as to whether I want to put this on my car, what could the negative aspects be? I can see extra wear on the cables for sure pulling the latch mechanism with the extra pressure exerted by the upgrade springs.
Old Apr 5, 2011 | 09:29 PM
Dave C's Avatar
Dave C
I feel your pain Midnight - why would they be the only vendor that has this? What exactly gets upgraded with their kit? Is it something that can be homemade?
Dave C
