yesterday I went to car (90 convet) and the passenger seat makes a loud almost grinding sounds and wont move foward or back. I know time to replace the motor; My question is how can I move the seat to access the rear seat bolts to get the rails out? any ideas are welcomed
use a gear wrench, after you've removed the seat itself, if you havent already. BTW I have a new rebuilt one for sale over in the for sale section $100 plus shipping
You should be able to remove the lower seat cushion, then remove the 4 bolts that hold the lower seat pan to the motor/track assy and lift the seat out. Then you shold be able to access the entire track mechanism.
the transmission is the weak point on these. I bought a seat track assy from the bay, and it cost more than the previous post. The catalogs want $200+ & core.
