correct pushrod length
Old Apr 6, 2011 | 11:17 AM
bill925's Avatar
bill925
Default correct pushrod length
is there anyway to tell what length pushrods you need without going through and installing the roller rockers? just trying to see if i gave you all the specs on the heads and cam and knowing im using ls7 lifters...could anyone tell me what pushrods i need?
heads:
LT1 LE2 heads consist of :
Manley 2.00/1.56 6000 series valves
Patriot Gold Extreme springs (155 lbs seat and 400 lbs open)
Steel retainers and locks
205 cc intake port
milling, cleaning and assembly
flow about 275/190 CFM
cam intake exhaust
duration at .050 236 244
lobe lift .3700 .3700
seperation 112 op-cl op-cl
timing events .050 9 47 57 7
duration at .006 288 296
gross valve lift .555 .555
valve lash(hot) .000 .000
degree intake lobe to 109
Old Apr 6, 2011 | 11:20 AM
cv67's Avatar
cv67
St. Jude Donor '05
Youre going to have to get a pushrod length tool and 1 rocker on to check it properly no way around it.
Thats one component you dont want to get wrong.
Buy some good 1 piece rods too, dont cheap out.
Old Apr 6, 2011 | 11:31 AM
mmracecars's Avatar
mmracecars
check out oepushrods they are in mt clemens,mi. they make alot of the pushrods other people are selling,they have checking tools also.my cylinder head guy told me about them years ago.
mike
Old Apr 6, 2011 | 12:12 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Karnak, the Magnificent!
Old Apr 6, 2011 | 02:39 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
You need one of these:
And one of these so you dont compress the lifter instead of open the valve:
What you do is assemble one lifter, checker pushrod, rocker, checker spring, and valve. use a marker to color the top of the valve before putting the rocker arm on. Rotate the engine so it opens and closes the valve a couple times. The worn off marker should be in the middle of the valve top. If it is to one side or the other the pushrod is too long or too short, adjust it accordingly.
Old Apr 6, 2011 | 02:50 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Hermetically sealed in a mayonnaise jar on Funk & Wagnell's doorstep since noon today! Good one, Gregg.
Old Apr 7, 2011 | 10:59 AM
bill925's Avatar
bill925
alright thanks guys i appreciate it...
Old Apr 7, 2011 | 02:34 PM
rickneworleansla's Avatar
rickneworleansla
These are the one's I used in my build but you will need to measure. Check out the link below for pics and info on how I measured for mine. Scroll to the bottom.
Trickflow Chromemoly Pushrods 7.150" (21407150)
http://forums.corvetteforum.com/c4-t...-needed-3.html
To correct pushrod length
