Running better
Old Apr 7, 2011 | 03:12 PM
Crowhater's Avatar
Crowhater
Default Running better
For some reason sense I started spraying my car I have noticed the engine has more power when I am not spraying, does this make any sense? It might sound crazy but it is true the car responds quicker and feels like it has more power. Am I just carzy or is there something to this?
Old Apr 7, 2011 | 10:13 PM
dizwiz24's Avatar
dizwiz24
Is this a wet or dry nitrous setup?
If you are spraying too much extra fuel, then you are running rich and I could imagine it'd be possible to be slower when spraying.
Youd have to be waaay rich, black smoke coiming out the back. etc.
The NX kit I had gave some recommended fuel nozzle jet sizes and recommended nitrous nozzle jet sizes.
The fuel jet size it recommended for a 100 shot was too conservative. I had to go down a jet or two to make the most power.
The biggest frustration for me with nitrous was how it made more power on a full bottle vs. a half empty bottle. Even if you heated that half-empty bottle up to the same PSI you sprayed at with a full bottle. It still would feel 'sluggish' compared to the punch from the full bottle. It was like making more power on a full tank of gas vs. a 1/4 tank of gas.
Old Apr 8, 2011 | 12:07 AM
jsiddall's Avatar
jsiddall
I can't think of any reason the car would run better after you had sprayed. Usually the opposite happens
Old Apr 8, 2011 | 01:31 AM
Crowhater's Avatar
Crowhater
I am running a nx wet system the only thing I can figure is maybe the engine had a bunch of carbon and I blew it all out spraying N2O. I have never had the half tank situation, I have a 15# tank and a heater.
Old Apr 8, 2011 | 01:08 PM
3D87C4's Avatar
3D87C4
I'm way out of my depth here, but...
The fuel injection book I've been reading discusses how the computer adapts to driving conditions. As an example they mention that if you take a DD to the drag strip the performance will improve run-to-run as the computer adapts.
Maybe that's going on here?
Old Apr 8, 2011 | 02:37 PM
jsiddall's Avatar
jsiddall
Maybe, but...
The main thing the computer learns is the AFR under different part throttle driving conditions based on the O2 sensor. However, nitrous is only engaged at WOT when the computer ignores the O2 sensor (in narrowband applications anyway) due to power enrichment.
I have never found my computer learns anything at the drag strip, and unless the car in question has a wideband O2 sensor I can't imagine how it could.
Jeff
Old Apr 8, 2011 | 10:50 PM
dizwiz24's Avatar
dizwiz24
i thought of something else...
Where is your inlet air temp? Are you spraying directly onto it?
Doing so can cause the computer just to dump fuel (run rich) because it thinks the air is extra dense (because its cold).
Relocate your IAT upstream of the nitrous nozzle if this is the case.
Old Apr 10, 2011 | 11:27 PM
Crowhater's Avatar
Crowhater
My N2O nozzle is right in front of the throttle body .
Old Apr 11, 2011 | 12:35 PM
dizwiz24's Avatar
dizwiz24
Im not familiar with l98 and where the iat temp sensor is.
Make sure you are not spraying on it.
Btw I saw your post on how you are running 15 lb bottle, that would help wth seeing consistent power across an entire tank regardless of level.
I was running 10lb bottle (nx wet system) with heater and nx insulated jacket.
Old Apr 12, 2011 | 12:09 PM
jsiddall's Avatar
jsiddall
If you are worried about constant pressure nothing is better than a NANO system. With that the bottle size really doesn't matter.
To Running better
