Cluster appears to work but...
Old Apr 20, 2011 | 01:41 PM
jcro61's Avatar
jcro61
It still lights up some what from where the crack is I wont have any of the collant temp/volt function. But I can live with that temporary while I figure out the main problem of why it flickers and does not always light up. I am about to remove the power supply and check it out and go from there. Thanks
Old Apr 20, 2011 | 02:23 PM
jcro61's Avatar
jcro61
So I just went out to the car to take it out and now its completely dead again.I love the posts I read while searching that said how "easy" of a fix this was.
Old Apr 20, 2011 | 04:13 PM
hooked073's Avatar
hooked073
Your post that your High beam indicator was on and everything else was blank was an easy fix. You had a bad ground. You said that fixed that problem. No one even you could have knowned that you had no other functions. You can offen have more then one thing wrong. Try not to bash!! Like others have said you can try to find a used one or you can send it in to one of the many electronic repair shops. Most even brake down what it is going to cost you to replace the things you may need.
Old Apr 20, 2011 | 05:07 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
It's been a long time and I don't know if Jim is still doing this, but as you're in Mass, Jim Adams in Salem may be able to help. I've bought LCDs from him in the past.
witchcityeng@yahoo.com 978-335-4096
Worth a shot.
Old Apr 20, 2011 | 05:57 PM
jcro61's Avatar
jcro61
Worth a shot.
I found his info and his shop address on a old post but I was unable to find him as I work near Salem. I will try his email and see what happens.
Old Jul 21, 2011 | 09:20 PM
betcorvette's Avatar
betcorvette
I know your posts are old, but, if you still have the problem, look at the dash with polarized sunglasses on and instead of bright squares, you will see the read outs. If so, the polarized film is available for about $15, colors cost @$99.
