Hot Starting Problems
Old Apr 19, 2011 | 11:56 PM
SpeedRacer61's Avatar
SpeedRacer61
Default Hot Starting Problems
89 C4 starts ok the 1st time but no matter if you run it 1 minute or 1 hours when you shut it off it wont start again for about an hour. Thought about leaking injectors so did a pressure test and it does leak down after shut off, but not sure its the injectors as there is not smell of gas and a shot of starting fluid will start it back up. Could it be a by pass valve somewhere and is there a way to check?
