Locating my bearings
I’ll be replacing my rotors this weekend and decided it’s time to replace the front bearings. TRW, Moog, what did you use and where did they come from? I don’t need a whole assembly, just the bearings and race…and some grease, I know how to pack my own bearings
These are made in the HUB, as a sealed unit thats a pressed fit and held in place by 4 bolts on the backside ( fronts) (rears are 3 bolt torx), and a very important thrust washer on the front side..
Which to use? Whatever the delco or OEM part is, just avoid (like the plaque) the aftermarket bearings that come from China that are discount price and discount quality.I think even the catalog vette stores offer the different grade of bearing assembly...their "value" part that is soft chinese steel or the OEM part that cost 3 times as much.
Expect to pay $150 or more for each decent bearing. The discount hubs sell for under $100 each and can be very attractive. You pay later as they say...
The expected life of a factory bearing is approx 80,000 miles.I've got twice that on my fronts and have done the rears 3 times..
The cheap knock offs start getting loose after 10,000. Some people say their "new" cheap bearings were looser than the old worn out OEM part.
Check each wheel by the grab-wiggle test. If you can wiggle in/out holding at 6:00 and 12:00 and feel any play, the bearing is suspect. If you can SEE the movement, its trash. Tolerances are tight.
My OEM went over 100K and 30 or so track days.
C4's eat bearings. They eat cheap ones, they eat expensive ones. Buy the cheap ones. The expensive ones are no better anymore, they're just as crappy and built in China but cost 6X the price.
That said, I know you'll still go buy $300 ones "just in case" so I apologize for wasting everyone's time.
Apparently you are unaware that the penalty for committing heresy against the Orthodoxy Gods on this forum is severe. You had better repent quickly before the fire and brimstone begins to fall.
My fronts have more miles than that, but My rears seem to wear out in less than 80K. Probably because mine is more of a straight line stress situation and not so much stress on the steering end..
Look at it this way...
You just made $600 !
They are pretty reasonable as well. You can choose NOS or top quality used.
