'85 Auto box
Old Apr 21, 2011 | 03:43 PM
Ant1981's Avatar
Ant1981
Default '85 Auto box
What's the round thing above the pan towards the left and what does it do?
Old Apr 21, 2011 | 04:05 PM
OkieC4's Avatar
OkieC4
Looks like the 2-4 servo cover...
On a 700r4 (or 4l60), 2nd and 4th gear use a band which is actuated by the servo you see sticking out the side of the case. 3rd uses the 3-4clutch pack and fourth applies the 2-4 band to the allready applied 3-4 servo (hence its name) So the theory goes, if the band is slipping it would slip in 2nd and 4th and if the 3-4 clutch pack was slipping - it would slip in 3rd and 4th
Old Apr 21, 2011 | 04:09 PM
Ant1981's Avatar
Ant1981
Cool, I noticed a leak, very small leak at the bottom of it. So I went over it with some RTV. The box was only rebuilt last year.
Old Apr 22, 2011 | 09:22 AM
Ant1981's Avatar
Ant1981
Infact, why would that even be leaking?
Old May 13, 2011 | 06:58 AM
Ant1981's Avatar
Ant1981
Well the oil ate away at the RTV sealant. So I have been considering removing the servo and changing the seal.
I'm not sure how confident I am about doing that and how well accessible it will be, even with the exhaust off.
Old May 13, 2011 | 10:33 AM
383vett's Avatar
383vett
I've removed mine from under the car. There is a pretty hefty snap ring that needs to be screwdrivered out. The cap then needs to be pried off (channel lock). Then the o-ring replaced. It's a little tough, but doable.
To '85 Auto box
