Wheels sizes
Old May 11, 2011 | 11:42 AM
Bowlesy's Avatar
Bowlesy
Default Wheels sizes
Hey guys, what size wheels can I fit on a '96 without them protruding past the fenders?
Old May 11, 2011 | 07:51 PM
oldalaskaman's Avatar
oldalaskaman
depending on offset , I vote for 12"
Old May 12, 2011 | 01:38 AM
vetteoz's Avatar
vetteoz
Factory 11" rims ('96 GS coupe) came with flares to cover top of wheel
ZR1's had wider rear panels to cover their 11" rims
Old May 12, 2011 | 01:43 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
10" max.
The 11" tires pass the fenders.
Old May 12, 2011 | 10:24 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
On my 92 I use 275x18 Hoosier R6 on 18x10.5" rims, on the rear its tucked in under the fender (if I was concerned with it I'd use an 1/8" spacer). On the front its even or a little under the fender lip.
Old May 12, 2011 | 08:28 PM
Bowlesy's Avatar
Bowlesy
Cool. Thanks for the feedback guys!
Old May 13, 2011 | 02:13 AM
Qiken's Avatar
Qiken
Replies have covered from 10",11" and 12" wheels interesting,I have aftermarket wheels 10.5" rear and curious what max tire width I can run without protruding past the fender flare on the rear.
Some have very rounded side wall's where it meets the tread and some have a more square shoulder on them.....Any one have pic's running 10.5"-11" wheels on rear without tire protruding?
Old May 13, 2011 | 03:58 AM
themadvetter's Avatar
themadvetter
My 96 has rear 10.5's and as you can see the tires protrude about a 1/4".
Old May 13, 2011 | 04:25 AM
Qiken's Avatar
Qiken
Terrific Thanks."themadvetter" that gives me a good indication,I have an 89 vert (believe the fender flare is the same) What make and size tire are you using and does it bulge off the wheel at the top much?
Any other members pic's? including a picture from the "rear" (you know what I mean LOL)
Old May 13, 2011 | 04:39 AM
themadvetter
Michelin 275/40/zr 18" pilot sport a/s
Old May 13, 2011 | 05:19 AM
Qiken's Avatar
Qiken
Im in trouble,I want to fit 315/35/17
Old May 13, 2011 | 10:40 AM
Bowlesy's Avatar
Bowlesy
Lower profile tires may bulge a bit less. 1/4 inch isn't too bad. I could definitely live with that. Too bad I can't take the rear of a GS and put in on there. I think I'll go 10.5" on the rear.
To Wheels sizes
